Visitors: 59
Total: 59
01: Home
22: Event Calendar
51: Event Calendar
1 2 3 ... 48 49 50 ... 103 104 105
1969Baja
1969Baja
Posted: Sat Sep 25, 2010 03:20 AM
Installed the new 1 1/2" U-bend exhaust. Dang that thing is loud!! Nothin better than working in the apartment complex parking lot...
Posted: Sat Sep 25, 2010 09:34 AM
got a brand new set of tires for the front of my baja. wow what a difference it makes driving down the road. Smile
Posted: Mon Sep 27, 2010 05:09 AM
thext94 wrote:
Is there a tech inspection that needs to be passed to for pre-running?
Nope. You are responsible for making sure your pre-runner is up to it and safe enough.
Posted: Mon Sep 27, 2010 05:41 AM
Got baja62s Baja running again, then it ran out of gas, before I could make final adjustments.
crickifur
crickifur
Posted: Mon Sep 27, 2010 05:44 AM
hmmm what didnt I do to mine?? lmao darn VWs Grrrrr
Posted: Mon Oct 04, 2010 12:26 AM
Today I finished up welding some damage from all the hard runs I have been on in the last two years. The cracks really grew larger after the Ajax Mine Wash run.
I also finally installed new brackets for a reverse light and relocating the tail lights.
Here is a view of the hit on the seat bracket tube. Note the two cross bars I had installed to keep big rocks out. Also note the old bit of square tubing that held the fiberglass seats.
I was a bit close to the steering wheel.This tab to tilt the seat rearward should do the trick.
I also got around to making the right mirror mount
crickifur
crickifur
Posted: Mon Oct 04, 2010 12:50 AM
sheesh! Perrib what a list of stuff! hahaha... Ive just starte working on the wiring today myself, itll be fixed tomorrow and possibly a small run after school tuesday to test everything out!
Posted: Mon Oct 04, 2010 03:55 PM
Installed a switch box with 4 switches and stereo in the Old Mans Baja, tonight I will be rewelding the roll bar and rear bumper welds that broke.
crickifur
crickifur
Posted: Tue Oct 05, 2010 12:24 AM
WOOHOO! Repaired my fuse block (was shorting out on the frame), got my headlights working, as well as my tails and am ready to go. I can actually drive at night without blinding the person in front of me! Although, if Eric ends up there again, I may just do it anyway... Razz
crickifur
crickifur
Posted: Tue Oct 05, 2010 03:10 AM
Hmmm WELL! Thought I fixed the headlights... They worked great for 10 min, they flashed once and now they are completely off! hahaha..... Tailights and markers work great but no headlights..... This thing is gonna be the death of me lmao.... Non stop for a month and a half, thought I was done today, and now just more work GRRRRRR :/
Posted: Tue Oct 05, 2010 04:12 AM
Just another day in the life of a VW owner. Smile
crickifur
crickifur
Posted: Tue Oct 05, 2010 06:10 AM
I think its almost funny to be honest. Im not spending anything on it to fix though I have to say hahaha, I have spent enough for a while lol. I guess it just wants to be hard wired. Ill play hardball lmao...
Posted: Wed Oct 06, 2010 02:57 AM
I went urban off roading. Found a few streets flooded enough that the floor of the rail was under water. Smile
crickifur
crickifur
Posted: Wed Oct 06, 2010 05:04 AM
HAHAHA I DID THAT IN MY GRAND AM!! LMAO I even got to see a car floating today!!
Other than that though, there wasnt anything wrong with the lights on mine after all, Im just a moron, took 2 seconds to "fix". I did test out the river bed though and I have to say, the car held its own!
Rybob
Rybob
Posted: Wed Oct 06, 2010 07:49 PM
Pulled it into the carport and finally hammered enough at the front end for my new nosebowl to fit! Very Happy also finished sanding w/ 320 grit on the body. Now time to get it down to 600 grit before paint Cool
(o\|/o)
4 Admin_AzBaja 6194 Baja Bugs on Wiki need...
285 MusicManiac 230094 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 421 Re: Had to go play in ...
0 Northmountainauto 1013 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 2917 Baja hiding in Chandle...
