Visitors: 90
Total: 90
27: Event Calendar
60: Pictures
84: My Account
88: Home
FABINC 5-1600 Build
1 2 3 4 5 6 7 8 9
Posted: Mon Oct 04, 2010 12:06 AM
It is looking good. Smile
Posted: Mon Oct 04, 2010 03:18 AM
Thanks for the support.
The foundation was really solid and the body relatively straight. Hoping to be done before years end. Weather and cash flow permitting!
VIN70
VIN70
Posted: Mon Oct 04, 2010 03:24 AM
i like how you didnt cut a hole in the firewall for the pedals, looks like you had to move the seat back quite a bit though
VIN70
VIN70
Posted: Mon Oct 04, 2010 03:26 AM
Posted: Tue Oct 05, 2010 05:07 AM
Fact is the guy who had the car before me was really tall and trying to reach the pedals and shifter would have been a problem. Relocating both the pedals and shifter made it a lot easier and it keeps everything out of the tunnel for maintenance purposes.
Posted: Sat Mar 12, 2011 11:52 PM
UPDATE UPDATE UPDATE>>>
Just fabricated some streamline nerf bars. Finished up the body work and it is off for paint. Will update photos once it is out of paint booth.
JumpinBruceB
JumpinBruceB
Posted: Sun Mar 13, 2011 10:42 PM
Project is looking awesome glad to see some more progress. I really like the stream line nerf bars
Posted: Tue Mar 22, 2011 01:18 AM
Just got it back from the paint booth on Sat. I am going to let it sit a couple weeks while I finish up the engine. I went with a medium grey metallic.
[img][/img][img][/img][img][/img][img][/img][img][/img][img][/img]
Posted: Wed Mar 23, 2011 12:08 AM
Looking nice.
Posted: Wed Mar 23, 2011 06:02 AM
I like the color. I used a similar color for trim on mine...trailing arms, shift lever, brake handle, engine tins, etc.
bajabuggin
bajabuggin
Posted: Wed Apr 20, 2011 01:11 AM
Have you tried to install the engine yet? i had to cut the driver side rear railing out where it ties into the tranny horns. it was rubbing on the headers. ill post some pics when i get a chance on what im talking about.
bajabuggin
bajabuggin
Posted: Wed Apr 20, 2011 02:50 AM
Also what gauges did you use? not sure whats needed and whats not. thanks
Posted: Wed Apr 20, 2011 05:20 PM
For offroad racing, I don't recommend gauges in front of the driver. Not likely to have a chance to look at them. The co-driver can. If you decide to install gauges, the ones I suggest are:
- Oil Pressure
- Oil Temp.
A tach is only of use to a driver to determine shift points or for analysis of gear ratios.
bajabuggin
bajabuggin
Posted: Thu Apr 21, 2011 02:47 AM
thanks for the info, im not going to be racing (yet).
Posted: Thu Apr 21, 2011 07:59 PM
I got that impression, but playing is not that much different. And if/when you decide to race, you will know already.
1 2 3 4 5 6 7 8 9
26 1963BAJA 7926 The Socal Honda Build
 Fri Jun 23, 2017 12:15 AM
1963BAJA View latest post
Cheapskate special
26 Azdrtdog 12046 New father/son budget ...
 Fri Jun 16, 2017 10:26 PM
No new posts Projects and Builds New Class 11 Build - PepeBlanco 4 pepeazul 5435 New Class 11 Build - P...
101 SuburbanLegend 137559 Carbon Footprint...aka...
 Thu Oct 08, 2015 08:28 PM
No new posts VW Volkswagen & Baja Bug General Discussion 5-1600 vs Class 11 Version 3 2 wideopenmotorsports 3517 5-1600 vs Class 11 Ver...
 Thu Oct 08, 2015 08:12 PM
