Latest: hulkbaja
Overall: 3594
Visitors: 82
Total: 82
11: Event Calendar
24: Event Calendar
32: Pictures
47: Event Calendar
64: Event Calendar
71: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- I need some help getting some loose ends tied up
JumpinBruceB
JumpinBruceB
Post Post subject: I need some help getting some loose ends tied up
Posted: Sat Sep 25, 2010 02:19 AM
Ok so here are my issues
-Engine running real rough if at all. Tried to adjust the valves and timing and that only seemed to make it worse. Did not test compression
-Having a hard time starting out in first. I have to slip the clutch for way to long and if I don’t I get a bad back and forth jerking.
-Black Plugs. Brand new only a few hours on them.
-Seems to be burning oil. Has a bit of white smoke coming from the exhaust.
-Back firing when the rpm's come down
-Battery Draining over a period of about two days
-Large oil leak. Not sure where it is coming from it kind of looks like the push rod tubes but it also might be coming from the case. Its way to junked up down there to see anything.
New parts….
-Complete rewire
-New carb
-New plugs,wires,dist cap and rotor, exhaust gaskets
-probably a few other things but I can’t remember
I have been having a real hard time with the Baja and have not been working on it much because of that. I guess I just don’t know what I’m doing or I just don’t know how to read and interpret directions so I need some help. I wish that I lived closer to you guys so I could have some hands on help that would make things much easier to learn. So please help me decide what I should do to fix things and learn a little along the way. I took it to the local VW shop where I have been getting my parts and had them do the wire and some other things but quality of work is not up to par. I would like to get this thing running smooth and back on the trail so I can enjoy it. Please help me diagnose my problems so I can go about fixing them. If you think I need to pull the motor and rebuild the whole thing then tell me. If you think I’m an idiot and don’t know what I’m doing and should stop then tell me I just need honest advice on how to change my Baja situation. Thank You guys so much you have been a great help throughout my build
Post Post subject: Re: PLEASE HELP ME I AM IN DESPERATE NEED OF HELP!
Posted: Sat Sep 25, 2010 02:57 AM
A rewire with an original harness is about 6-8 hours plus the harness. About $700 or more at most shops.Even when new, Bug wiring look like a controlled rats nest. Yes they should of checked it for a parasitic draw. Post a picture.
A new carb and labor is at least $200 black plugs no heat risers, stuck choke etc.
Rear wheel bearing (one) $100
Major service $175 Did you tell them it needed to pass emissions?
Did they tell you more work was needed to make it right?
The price is pretty normal but not the service. Did they tell you more work was needed to make it right? If not you should of brought it right back. Now you might have waited to long.
JumpinBruceB
JumpinBruceB
Posted: Mon Sep 27, 2010 06:55 PM
No they did not say that there would be any additional work needed. I thought the price was alright but the work was just sub par. Wire harness was not included in the cost. Not sure what you mean by no heat risers, like they are blocked. If it is the choke how can i fix? Thanks
Posted: Mon Sep 27, 2010 11:31 PM
It appears so. Why did you not return to get them to warranty the work?
JumpinBruceB
JumpinBruceB
Posted: Tue Sep 28, 2010 08:42 PM
to be honest i am not really sure. I was just so fed up with everything I was having trouble with and then when I decided to pay to fix it i got screwed once again. You ever had those moments where you just didnt want to deal with something anymore...this was it. I guess i could try to go back but its been to late now which is why I am asking you.
Post Post subject: Re: I need some help getting some loose ends tied up
Posted: Wed Sep 29, 2010 02:33 AM
Mow it is tome to get a book on automotive wiring basics and the Bentley manual (The Samba has the Bentley wiring diagrams on line.) but you still need it for procedures and specificatons. Once your familiar with voltage drops and dead short testing you can fix your wiring.
If you do your Google homework there is plenty of data out there on diagnosing carb troubles. You may even be lucky enough to have a bad new carb or possibly your starting in 3rd instead of first gear.
JumpinBruceB
JumpinBruceB
Posted: Thu Sep 30, 2010 10:59 PM
Definitely not starting in third...give me a little credit haha. Ordered the books yesterday should be here this week. Also having trouble with the brakes, whenever I put even the slightest bit of pressure on them it pulls me hard left . Any ideas.
Brettucks
Brettucks
Posted: Fri Oct 01, 2010 04:27 AM
Gotta start at the begining... get the battery probs and engine probs first..
While figuring out wiring get a compression test or buy a gage to do it... it may answer many motor questions you have as far as plugs, idling, oil use and leaks etcetc..
Perri Knows his stuff and any advice he says take at face value...
-Brett
Posted: Fri Oct 01, 2010 04:45 AM
I had to ask since in the past I have seen it many times. The brakes are only working on the side it is pulling towards.
JumpinBruceB
JumpinBruceB
Posted: Sun Oct 03, 2010 05:44 AM
Ok thanks I will update when i get a little more info for you. I gladly take everyone's opinion with an open mind thank you guys for all the help.
Brettucks
Brettucks
Posted: Sun Oct 03, 2010 06:57 PM
a couple more questions-- You must have driven it to know about the brakes- so did you get to go through the gears or putting around in first? This will help figure out why its hard to take off in 1st (is it first only or is it fine once it's going?). I understand the asking about 3rd gear- bad coupler but I see you replaced yours.. even after replacing mine took 3 tries to get the shifter in just the right spot to get all gears
And for the wiring- once you know how to use a meter to find parasitic loss then it gets easy to isolate which wire/wires are the culprit.
As for the brakes you can have someone push the pedal while you watch at the caliper/brake shoes, or jack up and spin by hand while someone brakes- should be easy to see whats not working.. If you havent purged all brake fluid and replaced it and bled the brakes do so first. The stock brakes are not self adjusting so if they all move (not stuck) they may need adjusting. if any brakes dont move the wheel cylinder might need replacing.
No new posts VW Volkswagen & Baja Bug General Discussion Help IDing Front Ends?
22 catchbats 6258 Help IDing Front Ends?
 Fri Feb 20, 2009 12:16 AM
Wiggins View latest post
No new posts VW Volkswagen & Baja Bug General Discussion king pin spindles and ford tie rod ends ? 10 DRUMMOND 4854 Re: king pin spindles ...
 Sat Feb 02, 2008 05:37 PM
No new posts VW Volkswagen & Baja Bug General Discussion One piece front ends 0 Roadrunner 1256 One piece front ends
 Fri Aug 17, 2007 07:45 PM
Roadrunner View latest post
No new posts VW Volkswagen & Baja Bug General Discussion One piece front ends 7 BugZyla.com 3460 Re: One piece front en...
 Sat Jul 08, 2006 07:26 AM
