Visitors: 151
Total: 151
02: Pictures
12: Event Calendar
20: Event Calendar
25: Pictures
45: Event Calendar
51: Event Calendar
63: My Account
69: Home
87: Event Calendar
108: My Account
113: My Account
114: Pictures
130: Event Calendar
150: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Floorpans
Floorpans
Ken48442
Ken48442
Post Post subject: Floorpans
Posted: Tue Sep 21, 2010 02:03 AM
I got the body off the pan. Took a little longer than I thought. I had all the bolts out but the rear end wouldnt budge. After sloder inspection I found that one of the previous owners had welded the body to the pan in two places in the rear. A few minutes with an air chisel took care of that and the body came right off.
I need to get floorpans. I saw some sites advertising heavy duty 18 gauge off road floorpans. A these worth the extra money or are the standard pans adequate?
1969Baja
1969Baja
Posted: Tue Sep 21, 2010 05:28 AM
I say get standard pans and then put a skid plate on the bottom. But that's just my opinion.
Post Post subject: Re: Floorpans
Posted: Tue Sep 21, 2010 08:03 AM
New standard pans will work just fine. The HD pans can be a pain to manipulate into fitting sometimes. As long as you dont jump the car and land dead center on a rock the standard pans will hold up just fine. If your worried about rust, just bedliner the pan when your done putting them in.
Posted: Tue Sep 21, 2010 10:27 PM
x2 ... As Bugzyla said... + the Bedliner while you have the body off is the ticket...
Ken48442
Ken48442
Posted: Wed Sep 22, 2010 01:31 AM
Do you coat both sides of the floorpan with bedliner. How about the rest of the frame and front beam?
Posted: Wed Sep 22, 2010 06:15 AM
I would coat as much as you can. Cheap insurance against rust!!!!
Posted: Sun Oct 03, 2010 02:41 AM
Idea Laughing Idea Wink Idea
Tractor Supply has a brush-on bed liner kit by, "Herculiner"...
Includes .. 1gal. of bed liner... brushes... roller... and some other stuff...$ 99.99
1qt. of Herculiner for $ 29.99
A friend of mine did his (daily driver) Dodge pick up several years ago and it had held up to our Mi. winters and road salt. Idea
Posted: Sun Oct 03, 2010 02:45 AM
I did some of the herculiner on my pan awhile back. Then, I picked up some of the dupli-color liquid bedliner and liked it a WHOLE lot better. The Herculiner was very coarse and abrasive- hurts to scrape your knuckles on. The Dupli-color went on very smooth and had a very nice finish when done. Very cool stuff. Wish I'd have done the inside of the car with it instead of the abrasive stuff.
Just my observation. Hope that helps.
