Visitors: 117
Total: 117
15: Pictures
24: Pictures
40: My Account
42: Event Calendar
53: Event Calendar
71: Event Calendar
82: Pictures
85: Event Calendar
94: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Can you dune a Baja Bug in Glamis, Dumont etc...
fast_1
fast_1
Post Post subject: Re: Can you dune a Baja Bug in Glamis, Dumont etc...
Posted: Tue Oct 14, 2008 08:38 AM
Wow that was pretty sick build. I like how he kept the stinger at first, but the turbo seems like more fun.
Just curious about some of the details on that car, if anyone has checked it out. On most of the baja's I've seen on here the cage goes all the way through the sheet metal in front. On that baja it was bolted through. Is that strong enough? That's how T_Town set up the rear engine cage on mine, but it's not an integral part of the chassis and doesn't really have any load on it, unless I back into a tree Shocked It seems like it must be fine since he jumped it a bit and it didn't break.
fast_1
fast_1
Posted: Tue Oct 14, 2008 07:46 PM
I was thinking, since his wheelbase isn't stretched the beam is still bolted to the frame head right? So that would limit the necessity to have tube going through the sheet metal?
Deiss923
Deiss923
Posted: Tue Oct 14, 2008 11:56 PM
Thanks for the link, that was really close to what i had pictured in my mind - the subaru motor. i was even planning on reducing weight by chopping the top for the roll cage and removing the doors, perhaps fabbing some fiberglass or something there like jeeps and oldschool broncos have+ it will increase your line of sight...still not sure yet about which way ill go (baja vs rail) but now you really got my gears spinning!
Posted: Wed Oct 15, 2008 03:44 AM
Deiss923 wrote:
...perhaps fabbing some fiberglass or something there like jeeps and oldschool broncos have+ it will increase your line of sight...
I don't know about anyone else, but I have YET to see that done to where it still looked decent. I don't think I'd part with the doors. If you pull the glass out of them, they don't weigh much at all. If there IS a small weight penalty, I'd probably still take that just for the safety of still being somewhat enclosed in the car.
Just my .02.
Deiss923
Deiss923
Posted: Thu Oct 16, 2008 11:14 AM
thats true i guess after gutting the door it wouldnt make too much of a weight difference in the grand scheme of things compared to fiberglass...especially knowing how me and my buddy are we'd probably get a little too crazy with the epoxy! Very Happy
neon99
neon99
Posted: Mon Oct 20, 2008 04:22 AM
Yeah all he did was cut the top half of the frame head off because it started out as a bj front end and he switched to the lp. So the beam bolts in the stock location for the bottom and he just fabbed up the top part because he didnt want to cut the whole front off to switch to a lp framehead. In his post he came to the conclusion that any force on the top beam would not be pushing the bars threw the fire wall but pulling it away because the beam would pivot at the lower mounts and the force from driving would be coming from the front. When I switch to a lp front end Im gonna do it this way.. the car has not had any problems with the beam mounts and has been around and driven for a few years and in the video it looks like hes not afraid to beat on it either !!
fast_1
fast_1
Posted: Mon Oct 20, 2008 04:53 AM
Mine started out as BJ and was converted to LP, but it's been stretched 6" so I guess that it would necessitate it being tied to the cage. The extra length would put more stress on the frame-head and that would be bad juju.
atmkittn
atmkittn
Post Post subject: Can you dune a Baja Bug in Glamis, Dumont etc...
Posted: Mon Sep 13, 2010 07:58 PM
here is a few pics of mine.. I built from scratch all tube chassis.. and coils with 10" strech and 4" arms ,3x3's out back disc brakes alll the way around.. Im running a toyota 22r with 091... fun car and I have less than 10k in it...
Posted: Tue Sep 14, 2010 05:05 AM
Guess I have to agree with most everyone else. While it can be done, don't expect a "low budget" Baja to dune all that well. It will get around, but not in the big stuff. The Subaru one one the Sand Assoc site dunes pretty good, but he has between 25K and 30K in it. That's not fat off, I know, cause I will have about that in the ghia when it is all done. I do expect it to dune pretty good, but am still planning on keeping the rail. If you do go forward with the project, spend some money on a good strong low geared trans. It can make a stock 1600 feel like it has some power. Then you can add to it later. Just my thoughts. Good luck.
Posted: Tue Sep 14, 2010 05:25 AM
You can have fun on the cheap in a Baja. My friend had a 1600 cc turbo charged mostly stock Baja with paddles. He could not play king of the hill but it was pretty quick as it would out pull my 15 sec 1/4 mile off road engine up the hills at Gordon Wells and Patton Valley. I think he had about 2 grand in the whole Baja.
atmkittn
atmkittn
Posted: Fri Sep 17, 2010 06:27 PM
one of my first bajas back when I was just out of high school was really just a lil more than stock bug stripped with a link pin and irs trans.. it had a 1835 with a single mukuni... and it went damm near anywhere... fun lil car i ran 235/75 15 all the way around.. and never had any prob doing anything...
2500Grunt
2500Grunt
Posted: Sat Sep 18, 2010 02:08 AM
atmkittn:
Can you buy those front tires anywhere in Phoenix or is it a special order?
2332 turbo,IRS,bus tranny,4 seater
Posted: Sat Sep 18, 2010 03:56 AM
Front tires look like bias ply 700x15 Yokahama Super Diggers. You can almost run them flat.
4 Admin_AzBaja 6187 Baja Bugs on Wiki need...
1568 mufasavnvmc 954916 Re: what did you do to...
285 MusicManiac 229877 Re: Baja sightings
0 Northmountainauto 1004 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 2888 Baja hiding in Chandle...
