Latest: strike77
Overall: 3575
Visitors: 412
Total: 412
42: Pictures
44: Event Calendar
54: Event Calendar
58: Pictures
63: Pictures
64: My Account
84: Pictures
100: Pictures
106: Event Calendar
115: Pictures
131: Event Calendar
132: Event Calendar
134: Event Calendar
144: Event Calendar
146: Event Calendar
150: Baja Forums
157: My Account
158: Baja Forums
169: Home
170: Links
172: Links
173: Baja Forums
178: Baja Forums
179: Baja Forums
182: Event Calendar
183: Event Calendar
185: Links
186: Baja Forums
189: Pictures
190: Links
191: Baja Forums
194: Baja Forums
195: Baja Forums
197: Baja Forums
198: AMAZON.com
201: Baja Forums
202: AMAZON.com
204: AMAZON.com
205: AMAZON.com
206: Baja Forums
207: Baja Forums
208: AMAZON.com
209: Baja Forums
210: Event Calendar
211: Event Calendar
212: Baja Forums
213: AMAZON.com
214: Baja Forums
217: Links
218: Links
219: Pictures
220: AMAZON.com
221: AMAZON.com
222: Baja Forums
223: Event Calendar
224: Baja Forums
225: AMAZON.com
226: AMAZON.com
227: AMAZON.com
229: AMAZON.com
230: Baja Forums
231: Baja Forums
232: Links
233: AMAZON.com
234: Baja Forums
235: Pictures
236: AMAZON.com
237: Event Calendar
238: Groups
239: AMAZON.com
240: Baja Forums
241: AMAZON.com
242: Baja Forums
243: Baja Forums
244: AMAZON.com
245: Event Calendar
246: AMAZON.com
247: AMAZON.com
248: AMAZON.com
249: Baja Forums
250: AMAZON.com
251: Baja Forums
252: AMAZON.com
253: AMAZON.com
254: AMAZON.com
255: Baja Forums
256: AMAZON.com
257: AMAZON.com
258: AMAZON.com
259: AMAZON.com
260: Baja Forums
261: AMAZON.com
262: AMAZON.com
263: AMAZON.com
264: AMAZON.com
265: AMAZON.com
266: AMAZON.com
267: AMAZON.com
268: AMAZON.com
269: AMAZON.com
270: AMAZON.com
271: Baja Forums
272: AMAZON.com
273: AMAZON.com
274: AMAZON.com
275: Baja Forums
276: AMAZON.com
277: Baja Forums
278: Baja Forums
279: AMAZON.com
280: Baja Forums
281: AMAZON.com
282: AMAZON.com
283: Baja Forums
284: Baja Forums
285: AMAZON.com
286: Baja Forums
287: Baja Forums
288: Baja Forums
289: Pictures
290: Baja Forums
291: AMAZON.com
292: Baja Forums
293: AMAZON.com
294: Baja Forums
295: Baja Forums
296: AMAZON.com
297: AMAZON.com
298: AMAZON.com
299: AMAZON.com
300: AMAZON.com
301: Baja Forums
302: Baja Forums
303: Baja Forums
304: Baja Forums
305: AMAZON.com
306: AMAZON.com
307: AMAZON.com
308: Baja Forums
309: Event Calendar
310: Baja Forums
311: Links
312: AMAZON.com
313: AMAZON.com
314: Baja Forums
315: AMAZON.com
316: AMAZON.com
317: AMAZON.com
318: Baja Forums
319: Baja Forums
320: Pictures
321: AMAZON.com
322: Event Calendar
323: AMAZON.com
324: Baja Forums
325: AMAZON.com
326: AMAZON.com
327: Event Calendar
328: Baja Forums
329: Baja Forums
330: Baja Forums
331: Baja Forums
332: Baja Forums
333: AMAZON.com
334: Baja Forums
335: AMAZON.com
336: AMAZON.com
337: Baja Forums
338: Event Calendar
339: Baja Forums
340: AMAZON.com
341: AMAZON.com
342: Event Calendar
343: AMAZON.com
344: Event Calendar
345: AMAZON.com
346: AMAZON.com
347: Baja Forums
348: AMAZON.com
349: Baja Forums
350: Baja Forums
351: Baja Forums
352: Baja Forums
353: Event Calendar
354: Baja Forums
355: Baja Forums
356: AMAZON.com
357: AMAZON.com
358: AMAZON.com
359: Baja Forums
360: AMAZON.com
361: Baja Forums
362: Baja Forums
363: Baja Forums
364: Baja Forums
365: Event Calendar
366: AMAZON.com
367: Baja Forums
368: AMAZON.com
369: News Letter
370: Contact Admin
371: AMAZON.com
372: Baja Forums
373: AMAZON.com
374: Baja Forums
375: Baja Forums
376: Baja Forums
377: AMAZON.com
378: Baja Forums
379: Baja Forums
380: AMAZON.com
381: Baja Forums
382: Event Calendar
383: Baja Forums
384: Baja Forums
385: Baja Forums
386: Baja Forums
387: Pictures
388: Baja Forums
389: AMAZON.com
390: AMAZON.com
391: AMAZON.com
392: AMAZON.com
393: AMAZON.com
394: AMAZON.com
395: Baja Forums
396: AMAZON.com
397: AMAZON.com
398: Baja Forums
399: Baja Forums
400: My Account
401: AMAZON.com
402: AMAZON.com
403: Baja Forums
404: AMAZON.com
405: Baja Forums
406: AMAZON.com
407: AMAZON.com
408: Home
409: Baja Forums
410: AMAZON.com
411: Baja Forums
412: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- swing and irs torsion
72BajaBen
72BajaBen
Post Post subject: swing and irs torsion
Posted: Tue Oct 24, 2006 07:14 AM
so i saw over on STF a question, and i was wondering the opposide. I have an IRS tranny, lets saw for some reason i wanted to put a swing on there, would i just have to take the trailing arms off, replace the spring plates and use a swing axle tranny? can the same toraion bars be used? is it even the same torsion?
what im getting at is ....when i get around to building my rail ( probably more later than sooner) can i just find one with a IRS torision housing on it and use a swing if i wanted to make a class 9 buggy. or is it all different.
Post Post subject: Re: swing and irs torsion
Posted: Tue Oct 24, 2006 07:20 AM
You will need swing axle spring platesand matching torsions or cut IRS spring plates and matching torsions.
bajasam96
bajasam96
Yes, But you will need new spring plates too, and I am not sure if the spline is the same for the tortion bar... But I do know it has been done. I know a guy who liked the lean-in tire look of a lowered bug so used a swing setup in a 72
72BajaBen
72BajaBen
Posted: Tue Oct 24, 2006 07:37 AM
sweet this way i can do either if i wanted, and i can widen my search for rail frames
cactusdog
cactusdog
Posted: Sat Oct 28, 2006 08:20 AM
I converted my 65 to IRS, the bad thing is that torsion sticking out makes 31" tires not an option. I found with irs torsion I could get more travel do to the longer torsion,wasted two sets of short swing axle torsion. Now I went back to the shorter swing axle torsion,but installed a set of airbags to take up the load,and set the torsion vary light. Now I'm not over twisting,and can adjust. They track much beter also,the air keeps them tires on the ground
72BajaBen
72BajaBen
Posted: Sat Oct 28, 2006 09:15 AM
i have 31" tires on my car
Posted: Sat Oct 28, 2006 05:31 PM
I run 31's with swing in my 59.
No new posts VW Volkswagen & Baja Bug General Discussion Coils Ver Torsion bar 12 Darn_Near 5873 Coils Ver Torsion bar
 Wed Oct 21, 2015 06:29 PM
thing View latest post
No new posts Projects and Builds Swing Axle Dual Shocks 2 dave46 3574 Re: Swing Axle Dual Sh...
 Fri Sep 11, 2015 08:06 PM
dave46 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion needed asap swing axle trans 5 Dirtjunkie 2616 needed asap swing axle...
 Fri Oct 12, 2012 06:10 AM
No new posts VW Volkswagen & Baja Bug General Discussion Rear torsion housing adjuster 3 ghettodish 4409 Rear torsion housing a...
 Fri Jul 01, 2011 12:44 AM
No new posts VW Volkswagen & Baja Bug General Discussion swing to irs 1 Luckyvw13 1703 Re: swing to irs
 Wed Apr 27, 2011 03:56 AM
