Visitors: 101
Total: 101
13: Event Calendar
17: Pictures
63: Event Calendar
75: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- CHECK YOUR PIVOT BOLTS!!!
Post Post subject: CHECK YOUR PIVOT BOLTS!!!
Posted: Thu Sep 09, 2010 07:12 PM
OK, Anyone with an IRS car, Check your pivot bolts!!!! I had one come out on the Fasty the other day. Lucky I caught it before it was a major problem.
I know for a fact the bolts were tightened, and I even put loctite on them, but they can work loose on you.
There is a fix for this, and I will post some pics next week when I do the mod to the fasty.
Posted: Thu Sep 09, 2010 09:08 PM
You probably have a pic of what you did on my car.
Posted: Thu Sep 09, 2010 10:38 PM
Zyla just get some of the pivot bolts that Doug's has. They have a regular hex head for a socket or wrench and they have a hole pre-drilled. Put em in and safety wire them around the torsion housing. after i did that mine have never come loose and if they do they're not falling out
No new posts New Members Transaxle Bolts stripped 7 LittleBaja 3657 Transaxle Bolts stripp...
 Tue Dec 01, 2015 05:38 PM
Broncoboy519 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion What size are fender bolts? 2 az350x 2852 Re: What size are fend...
 Thu Dec 02, 2010 11:30 PM
az350x View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Marks nuts and bolts on westside-- 3 Brettucks 2625 Marks nuts and bolts o...
 Sat Jan 30, 2010 06:18 AM
Brettucks View latest post
No new posts VW Volkswagen & Baja Bug General Discussion frame horn bolts 2 Colesifer68 2019 frame horn bolts
 Mon Jan 11, 2010 10:22 PM
Colesifer68 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Check your CV bolts...ask me why. 14 ditch68 6692 Re: Check your CV bolt...
 Sat May 03, 2008 01:15 AM
1FASTHOE View latest post
