Latest: xbluegto
Overall: 3573
Visitors: 270
Total: 270
23: Event Calendar
38: Home
72: My Account
84: Event Calendar
96: Pictures
112: Event Calendar
127: Event Calendar
150: Baja Forums
154: Baja Forums
157: Baja Forums
166: Baja Forums
171: Baja Forums
172: Baja Forums
178: Event Calendar
180: Baja Forums
185: Baja Forums
189: Baja Forums
190: AMAZON.com
191: Event Calendar
193: My Account
195: Baja Forums
197: AMAZON.com
198: Baja Forums
201: Baja Forums
202: AMAZON.com
204: AMAZON.com
205: AMAZON.com
207: Baja Forums
208: Baja Forums
209: Baja Forums
210: Baja Forums
211: Baja Forums
212: AMAZON.com
213: Baja Forums
214: Baja Forums
216: Baja Forums
217: Baja Forums
218: AMAZON.com
219: AMAZON.com
220: Baja Forums
221: Baja Forums
222: Baja Forums
223: Baja Forums
225: AMAZON.com
226: Baja Forums
227: Baja Forums
228: Baja Forums
229: Baja Forums
230: Baja Forums
231: Baja Forums
232: AMAZON.com
233: Baja Forums
234: Baja Forums
235: Baja Forums
236: AMAZON.com
237: Baja Forums
238: AMAZON.com
239: AMAZON.com
240: AMAZON.com
241: AMAZON.com
242: AMAZON.com
243: Baja Forums
244: AMAZON.com
245: AMAZON.com
246: AMAZON.com
247: AMAZON.com
248: Baja Forums
249: AMAZON.com
250: AMAZON.com
251: Baja Forums
252: AMAZON.com
253: AMAZON.com
254: Baja Forums
255: AMAZON.com
256: AMAZON.com
257: Baja Forums
258: AMAZON.com
259: Baja Forums
260: AMAZON.com
261: AMAZON.com
262: AMAZON.com
263: Baja Forums
264: AMAZON.com
265: AMAZON.com
266: Baja Forums
267: Baja Forums
268: AMAZON.com
269: AMAZON.com
270: AMAZON.com
Baja Forums -:- AzBaja.com Members -:- New Members -:- NEW GUY IN PHOENIX
NEW GUY IN PHOENIX
crickifur
crickifur
Post Post subject: NEW GUY IN PHOENIX
Posted: Tue Aug 24, 2010 05:46 AM
crickifur
crickifur
Posted: Tue Aug 24, 2010 05:51 AM
HEY THE PICS WORKED hahaha
So with the pics being posted, now you see what I have to work with. The frame and mesh flooring is perfect, the swing axle rear HAS GOTTA go, all the rims are rusted beyond use, the wiring harness will probably be getting changed out with a better self made one, and the frame will be getting powder coated after fabrication. A lot of the fun for me is just being able to restore an old buggy Very Happy That being said, does anyone know what kind of rail frame this is?? I know its from like 78 or 79...
Posted: Tue Aug 24, 2010 02:46 PM
WOW. Definetly needs a pressure wash and maybe a sand blast. Thats just alittle more work than I can take on right now. I have 3 cars to finish and 3 motors to build in the next month. Definetly check with Zyla he can take of all of that for you.
crickifur
crickifur
Posted: Tue Aug 24, 2010 02:48 PM
lol thats all good and as far as the sand blast goes, its getting powdert coated, the companies sandblast first anyway hahaha, but its all good, it needs work, but its gonna be a lot of fun Very Happy Thanks man
crickifur
crickifur
Posted: Tue Sep 07, 2010 12:52 AM
OK well, I havent updated this in forever it seems! Ive posted a couple areas but figured I would try to keep this up through my work in progress. The sand rail is no more! I stripped the chassis and did some bartering with Eric (dirtjunkie). I bought a 1966 beetle that was "converted" to a baja. The cutting was done and the baja kit was mocked up at best, it fits good and the body is in great shape as well as perfect fiberglass, but was missing a windshield that I have since bought. The car had no engine which I used from the rail. Eric and I spent a couple days working on the engine, but couldnt get the heads off the cylinders. We heated, beat, pryed to no avail. The good news was that everything inside the crank case and heads was beautifuly clean and the oil was like new (surprisingly). So with that being said, I bought all new tins, fuel pump, bolt on valve covers etc. to put the rest of the engine back together in hopes that it runs as great as it looks. We are pretty confident everything will be ok. The heads had solid Rocker Shafts and the valves moved freely. We completely assembled the engine and it is currently waiting to be installed. I also bought a single tube rear bumper that I have dropped off at Daryl's for some modifications and Ill have that back on Wed. I have cleaned up the jackman style rims and have a complete set of used tires that I will use for now untill all the kinks in the car are worked out. The goal was to have it up by this Thursday for the meet over here, but its looking really grim. Eric has been extremely busy (but helps whenever he can THANx ERIC), but my neighbors keep offering help and then bailing. I have to get the engine installed to make sure its good to drive. After that all I really have left to do is install the peddle assembly, bleed the brakes, install the windshield and weld in some seat brackets so I have a place to sit and take it for a test drive! Wish me luck and with any, Ill be on the road with it VERY VERY soon!
Posted: Tue Sep 07, 2010 01:25 AM
Looks good! Let's see the car!
TIP- carry a spare distributor cap EVERYwhere you go. Those see-through ones are notorious for cracking and leaving you stranded. That's what I've heard numerous times, anyhow.
crickifur
crickifur
Posted: Tue Sep 07, 2010 04:08 AM
OH OUCH!!!! I didnt think that it would make a difference! hahaha, plus it was $2 cheaper lol maybe thats why? Oh and here are some pics of the car I just took a few minutes ago... Its got the 7 piece kit including the rear valance, but i took it off today to try some things. I do plan on trimming the kit down some but have to figure out how small I want the fenders, right now they are just too low for my liking, it will be getting a light bar and a mentioned earlier, the rear bumper. Does anyone know where I can get some aluminum diamond plate for the firewall?? I would really like to get a piece in there, its proving to be a bit of a pain mounting things on the bumpy back end...
crickifur
crickifur
Posted: Tue Sep 07, 2010 04:20 AM
My first mod will be to swap to an IRS rear with 3x3 arms. After that eventually Ill move to the front at which point I am toying with the idea of changing to a 1 piece front end but I havent really decided. The front will get a +6 beam and link pin to get rid of that ball joint set up...
Posted: Tue Sep 07, 2010 04:23 AM
Did you put the pedals in it yet?
Posted: Tue Sep 07, 2010 06:00 AM
tell u wat chris, if u do change to a 1 peice front end ill buy the old fenders, hood, and nose peice off of u -David (Dirtjunkies jr junkie, son)
Posted: Fri Sep 10, 2010 03:16 AM
Helpful hints
REMOVE any non BOSCH ignition part and replace it with the correct BOSCH igntion part. Bosch platiniums are NEVER to be used in an air cooled engine. Sell the clear cap to the firt VW stoner you find as he will have hours of fun watching the spark. Got it.
crickifur
crickifur
Posted: Sat Sep 11, 2010 05:57 PM
HAHAHA well Ill just pick up an extra cap and use this one til it goes bad, no sense in wasting $$ As for the plugs, Ive used them in both my other VWs and they ran great.... And I will be getting a 1 piece for the front end, just not right away is all. Heres the pics of the engine in the car
wanabildabaja
wanabildabaja
Post Post subject: Re: NEW GUY IN PHOENIX
Posted: Sun Sep 12, 2010 02:34 PM
perrib wrote:
Helpful hints
Why should Bosch platinum plugs not be used in an air-cooled engine? What is the recommended plug? TY!
46 1engineer 30826 The Phoenix Manx
 Tue May 27, 2014 10:31 AM
No new posts New Members New guy from Phoenix 3 WarrenC 2920 New guy from Phoenix
 Thu Jan 16, 2014 04:52 PM
No new posts VW Volkswagen & Baja Bug General Discussion Question about local vendors in the Phoenix Valley areas 2 Salvo 2221 Question about local v...
 Fri Sep 20, 2013 07:37 AM
Sweetjumps View latest post
No new posts We Will Host Your Club Forum here New VW website for Phoenix area owners 7 biblethumpncop 8904 New VW website for Pho...
 Thu Sep 19, 2013 03:17 PM
No new posts VW Volkswagen & Baja Bug General Discussion Phoenix in October 5 Crash 4144 Phoenix in October
 Sat Sep 29, 2012 06:31 PM
Crash View latest post
