Latest: jamlip
Overall: 3581
Visitors: 145
Total: 145
14: My Account
27: Event Calendar
36: My Account
81: My Account
84: Pictures
90: Event Calendar
112: Event Calendar
114: Event Calendar
124: Event Calendar
145: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- 1960 baja HELP!
1960 baja HELP!
Andreeeyuh
Andreeeyuh
Post Post subject: 1960 baja HELP!
Posted: Thu Sep 02, 2010 05:31 PM
Help! I grew up with these, love em' to pieces, don't know much about the older ones tho. There's a 1960 for $800 I found and will usually just do everyday driving on it if I buy it, a little offroad fun---and
advice would help a lot! What kind of thing should I check when I go look at it? Does anyone know about this year? Pleeeeaaaasssseee help me!!
Post Post subject: Re: 1960 baja HELP!
Posted: Thu Sep 02, 2010 06:59 PM
No pictures??? No description of what it has and what you can see it needs? Shocked Welcome to AZBAJA. Here in Phoenix a pre 67 is a plus becuase there is no emissions requirement. It also has a link pin front end. In the rear the original transaxle had narrow splins so spinning a drum is easier to do than with the later long spline axles. Another negative is the swing axle has limited travel and require converting to a IRS to get more.
crickifur
crickifur
Posted: Tue Sep 07, 2010 01:14 PM
Yeah just make sure the car isnt rusted to crap, check the floor boards I mean thats pretty much it, everything else as mentioned above is all to preference. The swing axle is limited in what you can do to it as you can only get som much travel out of it, plus its foot print when lifted is messed up cause it actually causes the camber to be way off pulling the tops of the wheels out \__/ to kinda look like that. Basically your whole rear tires wont touch the ground, plus it doesnt handle as well coming out of tight corners, the IRS cures that problem and really isnt an expensive mod, Im actually working on doing the same to my car. Other than that, just make sure as much of the car works as possible, unless you dont mind doind a lot of wiring due to the fact that people tend to cut up the harnesses a lot not knowing what they are actually doing
4 Admin_AzBaja 6423 Baja Bugs on Wiki need...
1568 mufasavnvmc 975678 Re: what did you do to...
285 MusicManiac 235393 Re: Baja sightings
0 Northmountainauto 1220 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 3446 Baja hiding in Chandle...
