Visitors: 113
Total: 113
27: Home Page
46: Event Calendar
64: Event Calendar
110: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- 1960 vw baja surging/wheel hop problem
Post Post subject: Re: 1960 vw baja surging/wheel hop problem
Posted: Tue Jul 27, 2010 09:20 PM
I ran 30 mm Sway Aways in my rail with no problem. Try dual shocks. I ran triple KYBs.
hayduke
hayduke
Posted: Mon Aug 02, 2010 02:11 AM
well i talked to the vw guy at Sway Away, think the owner. He said 29mm short is just to much for my baja. So, i will have a pair of brand new 29mm sway away bars, they are the short ones. up for grab or trade if anyone is interested.
Posted: Mon Aug 02, 2010 03:04 AM
He might be correct unless you have dual shocks 29 mm bars are to much.
I asked a couple veteran racers who ran limited suspension when that was all there was how to set up my suspension. Dual Shocks was thier answer and as much bar as possible.
hayduke
hayduke
Posted: Mon Aug 02, 2010 02:02 PM
What I don't understand is wouldn't going with dual shocks just make it stiffer ? Thought the problem was I was to stiff?
Posted: Mon Aug 02, 2010 11:27 PM
Shock properly valved won't make it stiff. You might just want to use 24-26 mm bars if your after a soft ride or just raise your stock ones a bit by installing a center torsion adjuster. 29 and 30 mm bars are stiff and only ride smooth after 30 -40 mph and faster in rough terain. Mine was very stiff with 30 mm bars and 3 KYB shocks per side but it could be run in 3rd and 4th gear through rough terrain and scoccer ball size rock fields.
hayduke
hayduke
Posted: Tue Aug 03, 2010 04:40 AM
mine is bouncing 5mph till 70mph, however, if going to better shocks will allow me to run at 55 or 60 on the highway without bouncing i would rather put better shocks on and keep the 29mm. Would going with a really good Fox racing shock be the same as two kyb shocks?
Posted: Tue Aug 03, 2010 03:13 PM
It has been a long post how much tire pressure are you running? Much more than 15-20 psi will make the ride hard.
hayduke
hayduke
Posted: Tue Aug 03, 2010 04:14 PM
I have run 15psi to 32 psi. No real change the firm ride does not bother me. It's the bouncing that is the problem.
Posted: Tue Aug 03, 2010 09:20 PM
Have you put the stock torsion bars back in to see if the problem goes away?
If it does not a peek at the axle spades and fulcrums to see if they badly scored and locking up might be in order.
hayduke
hayduke
Posted: Wed Aug 04, 2010 02:40 AM
don't have the old bars anymore.
5 Admin_AzBaja 7140 Baja Bugs on Wiki need...
1568 mufasavnvmc 1013157 Re: what did you do to...
285 MusicManiac 244612 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 305 FREE VW BAJA'S
0 Northmountainauto 1705 Shop Baja
