Latest: strike77
Overall: 3575
Visitors: 116
Total: 116
02: Event Calendar
10: My Account
22: Home
45: My Account
53: Home
63: My Account
64: Event Calendar
90: Home
91: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- 90xj's baja build
90xj's baja build
1 2 3 ... 9 10 11
The following users give thanks for this topic Anonymous - Fri Mar 20, 2009 12:17 PM
navynuke
navynuke
Post Post subject: 90xj's baja build
Posted: Thu Apr 02, 2009 03:23 AM
I wish I had your fab skills. looking nice, I can do the labor, but not a good welder, and don't have the tools. ahhh the things to learn
Post Post subject: Re: 90xj's baja build
Posted: Thu Apr 02, 2009 03:26 AM
originally i was going to build one but i knew from the get go i didn't want any extra holes in the roof, nor did i want to weld it on. so i figured a modified stock one is gonna be the way to go for me. My car is fairly simple too, no 3x3s or coil overs, just standard width and pretty straight-forward.
the car looks like its coming along very nicely.
on a second note, i've never seen a oil filter literally blow up but i have seen one expand until the point where the rubber gasket eventually blew out, spewing oil everywhere.
90xjlimited4x4
90xjlimited4x4
Posted: Fri Apr 03, 2009 06:12 PM
Thanks that means alot this being my first rear build not counting the few bumpers I'm real proud of this thing!
90xjlimited4x4
90xjlimited4x4
Posted: Sun Apr 05, 2009 04:48 AM
well as this car has progressed i keep changing my mind and decided the right thing to do was drill and tap rather than the in out pump...
so i drilled and tapped the case tonight for the full flow setup all went well i used a shop vac to suck any metal that went the wrong way out tomorrow i will yank the oil pump and plug it so i can get the right cover on Monday i think i will be running some oil through the block before i bolt it all together!
Posted: Sun Apr 05, 2009 05:58 AM
90xjlimited4x4 wrote:
i have heard of people blowing up filters.... never seen it done. but that ph8a is a filter i had already so im going to use that for now. i plan to run a wix racing filter (much much more filtering capability than the fram comparable units)
when you say your running the same full flow system your running a "in & out" pump?
I have found theat the FORD FL1A filter is a works well too.
murphy_p
murphy_p
Posted: Thu May 28, 2009 03:05 AM
90XJ,
very nice buildup! Thanks for the awesome link to an actually affordable tube bender!! That's awesome!
how's the baja coming these days? noticed it's been a while.
awesome job, talk about inspiring!
Dream as if you'll live forever,live as if you'll die today. ~James Dean~
90xjlimited4x4
90xjlimited4x4
Posted: Thu May 28, 2009 05:38 AM
its waiting for cash its been sitting for 3 weeks without me touching it! im trying to sell two of my trucks to fund the finishing my bug and getting my jeep running!
90xjlimited4x4
90xjlimited4x4
Posted: Mon Aug 03, 2009 12:17 AM
ok ive been neglecting my baja buddys and my baja. moneys been tight and havent had the time nor energy to do much but today i knocked some things off the list! i know its not much but its something!
one of my friends "big bob" also know for his surf auto red single seat race car said that i needed these so i added them
added some supports for the rack now i know its not gonna move
so i got on the rack and took this picture
90xjlimited4x4
90xjlimited4x4
Posted: Sun Aug 09, 2009 05:18 PM
got a little more progress over the past couple days ran out of tabs and welding wire... shielding gas isnt far behind so updates will be slow but doing what i can with what i have
got the bumper mostly buttoned up
90xjlimited4x4
90xjlimited4x4
Posted: Tue Aug 25, 2009 02:51 AM
picked up a super shifter, brake lamps, fuel pump, oil cooler with fan, some dzus fasteners, brake lines frt and rear, bus master cyl, an fittings, clutch sleeve and wing nuts.
things i still need
hard brake line and fittings i have the flare tool
oil cooler hose
linkage between trans and shifter
head lamps
fuel pressure regulator
hood pin kits for fiberglass hoods (moore parts doesnt carry them)
and time to install that stuff! but having the parts makes it easier to make the time to install them.
90xjlimited4x4
90xjlimited4x4
Posted: Thu Jul 08, 2010 12:40 AM
the build isnt dead just been under wraps lately! business is slow so cash flow is at a trickle.
knocked off the list recently: shiftbox, shifter, clutch cable, throttle cable hood mounting. brakes and finishing the shift linkage are next week!
90xjlimited4x4
90xjlimited4x4
Posted: Fri Jul 23, 2010 06:30 AM
well i spent all day today working on brakes got the tabs made for the flex lines, started bending up the hard lines, welded up the tabs for the flex lines mounted the hard lines to the flex lines, filled the system with brake fluid started to bled the system and it leaks like a sprinkler all over the place Ive tried tightening the lines and it leaks anyways. so as of today i have a baja with brake lines that leaks.... probably give it another shot on stopping the leak tomorrow! No! No! No! No!!!!
90xjlimited4x4
90xjlimited4x4
Posted: Sat Jul 24, 2010 05:02 AM
got the leaks sorter out (for now) had to re-flare one of there flares... awesome craftsman ship. but the Rf wheel cylinder wont bleed its clogged internally so time to toss on the extra backing plates i have and the studded drums and get the front half bled.
90xjlimited4x4
90xjlimited4x4
Posted: Sun Jul 25, 2010 05:24 AM
well i got the studded drums and other backing plates on the car today bled the system i now have a rake pedal its not great but its there..... went to put the wheels on its awesome having studs to put the wheels on! tightened 9 of the 10 lug-nuts went to tighten the last nut it snugs up then the whole stud spins freely! im starting to think this bug has it in for me! Ive worked on the car every day and every day its presented me with a different problem.... so tomorrow i gotta pull that drum again. hopefully i wont kill the bearings like i did on the old drums so i don't have to replace a bearing too! needless to say im not having a good baja week!
90xjlimited4x4
90xjlimited4x4
Posted: Mon Jul 26, 2010 04:59 AM
well rather than pulling that drum today i bled the brakes again and welded up my shift linkage! i needed to get some momentum! Twisted Evil
Twisted Evil and i got it! then the car even stopped! ive been jazzed all afternoon the car drives out and back and stops even!
the bad:
my shifters lockout isnt working and first gear is hard to find... its a empi trigger shifter i bought new
i need to adjust the brakes, only one wheel locks up.
gotta check the trans fluid, i can hear the gears might be the huge hole in the floor though.
i broke my drop light, it was magnetized to the car and i forgot about it, when it broke it bent my air cleaner and swung by the wife and my father which took the yay it moved to wtf were you thinking! i fixed the light (mostly) and everyone's okay so it could of been alot worse
Shocked the socal bajas meetings Tuesday and what made me really happy was my wife brought it up asking if i could have the car street legal and ready by then. i said no but maybe by next month! Laughing
1 2 3 ... 9 10 11
4 Admin_AzBaja 5902 Baja Bugs on Wiki need...
1568 mufasavnvmc 925726 Re: what did you do to...
285 MusicManiac 223594 Re: Baja sightings
0 Northmountainauto 664 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 2308 Baja hiding in Chandle...
