Visitors: 143
Total: 143
29: Home
36: Home
37: Home
40: Pictures
69: Pictures
76: Home
81: Pictures
99: Event Calendar
114: Pictures
141: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- No Valve clearance, Please help
waterdude
waterdude
Post Post subject: No Valve clearance, Please help
Posted: Fri Jul 16, 2010 09:41 PM
Hi and greetings from Scotland.
I have a Baja that i bought recently and am in the process of sorting out all the problems caused by the previous owner (many many things to be sorted!)
I have been adjusting the valves and am having an issue with the exhaust valve on cylinder 2 all the other valve adjust nicely but i can get no clearance on the exhaust valve on number two.
I have the tappet nut and adjuster turned all the way out but still have no clearance.
Any advice or help would be greatly appreciated.
Thanks,
Stu.
madman74
madman74
Post Post subject: Re: No Valve clearance, Please help
Posted: Fri Jul 16, 2010 10:56 PM
Unfortunatly thats usually a sign of a worn valve seat. THe valve sinks deeper in the head. If its had a valve job recently, they might have cut the seat too deep. Have you tried shimming the rocker shaft?
Oops it broke!
Posted: Sat Jul 17, 2010 12:43 AM
x2.
If you look you will see the rocker hitting the valve keeper.
No new posts VW Volkswagen & Baja Bug General Discussion Broken Valve Adjusters 3 zfriek42083 2174 Re: Broken Valve Adjus...
 Sun May 20, 2007 11:51 PM
zfriek42083 View latest post
