Latest: BlackIrish05009
Overall: 3574
Visitors: 141
Total: 141
12: My Account
18: Event Calendar
36: My Account
54: Event Calendar
56: My Account
74: Event Calendar
96: Event Calendar
101: Event Calendar
103: Event Calendar
104: Home
126: Event Calendar
133: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- 1960 vw baja surging/wheel hop problem
hayduke
hayduke
Post Post subject: 1960 vw baja surging/wheel hop problem
Posted: Mon Jun 21, 2010 04:20 AM
hello all,
I have a problem with my 1960 vw baja, 1776 dual Kardrons, 29mm torsion bars, 1968 trans with welded third and forth, superdiff and rear truss bars. The problem is after i had the 29mm torsion bars put in I have a surging/wheel hop problem when i accelerate. When i put in the clutch the hop/surging sensation is gone. Then back on the throttle surging sensation wheel hop comes back. I have had two different vw mechanics check it and they can not find anything wrong. Thanks in advance if anyone can lead me in the right direction.
Posted: Mon Jun 21, 2010 06:39 AM
What size tires? and do you have to much ari in them? Also look and see that your not hitting the lower stop on your rear control arms you should have a min 2" drop when you jack the car up.
hayduke
hayduke
Post Post subject: Re: 1960 vw baja surging/wheel hop problem
Posted: Mon Jun 21, 2010 06:47 AM
tires are 235/75/15. I have run them at 20,30,15 no difference.
i'll jack the car up tomorrow and give her a look thanks.
Posted: Mon Jun 21, 2010 10:27 AM
I'm assuming you mean on take off in first gear. Solid or stock engine mounts? Upper and lower mid mount? Broken nose cone? Bad pressure plate? No bow in the bowden tube? I ran 30 shorts and never wheel hopped. You should fab up dual shock mounts and install dual shocks for 29 mm bars.
hayduke
hayduke
Posted: Mon Jun 21, 2010 03:58 PM
It does it in all gears under throttle as you go down the road.
it has solid mounts all the way around. It had a split case but welded in the adapter in the front when i went to the 68 long axle.
I have plans for dual shocks in back one day.
Nose cone does not seem to be broken
with out sound on this thing it kind of goes wha wha wha wha wha under throttle then all smooth when you put it in neutral and clutch in.
Posted: Mon Jun 21, 2010 07:06 PM
Describe it differently. Does it shake the whole time you accelerate?
Does it shake when you coast but leave it in gear?
Have you spun the rear wheels to see if an axle is bent?
Does it get worse as you speed up/
Video?
hayduke
hayduke
Posted: Tue Jun 22, 2010 02:02 AM
well its worse when i am accelerating. If in gear and coasting its still there just not as bad. However its worse when i'm going around 20 and 30 in second gear but its in all gears. I have spun the axles and they seem alright. I will try and take a video but with a stinger its going to be hard to tell. Before i put on the truss bar you could watch the stinger bounce when accelerating then stop when you put in the clutch and coasted.
Posted: Tue Jun 22, 2010 02:23 AM
Are the spring plate bushing worn out old rubber or new ureathane?
hayduke
hayduke
Posted: Tue Jun 22, 2010 02:45 AM
new 29mm sway away torsion bars with new urethane bushings.
Posted: Tue Jun 22, 2010 03:07 AM
Might need a video from the side and behind. Running out of ideas here.
Broken tire belt/ bent wheel.
Posted: Tue Jun 22, 2010 08:46 AM
I was thinking a bad tire, maybe broken belt or blister etc. Need to see it.
Posted: Tue Jun 29, 2010 05:44 PM
This problem ever get solved?
Posted: Tue Jun 29, 2010 06:23 PM
I was wondering the same thing.
hayduke
hayduke
Posted: Wed Jun 30, 2010 04:17 AM
Sorry vacation over have not fixed it yet to busy at work
hayduke
hayduke
Posted: Tue Jul 27, 2010 08:57 PM
ok after talking to several people over at Sway Away they say that with my 1960 bug swing axle i can not use 29mm bars. The bars are two stiff and causing the bug to bounce under throttle. So will have a brand new set of short Sway Away bars up for grabs.
4 Admin_AzBaja 5819 Baja Bugs on Wiki need...
1568 mufasavnvmc 915373 Re: what did you do to...
285 MusicManiac 221474 Re: Baja sightings
0 Northmountainauto 445 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1862 Baja hiding in Chandle...
