Latest: hulkbaja
Overall: 3594
Visitors: 120
Total: 120
29: Event Calendar
66: Drivers
72: Home
88: My Account
91: Pictures
110: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Fender nuts??
Fender nuts??
FIREHAZARD73
FIREHAZARD73
Post Post subject: Fender nuts??
Posted: Tue Jun 22, 2010 01:23 AM
When I took off the fenders of my 69 bug the nuts mounted in the body were so rusted half of the just twisted the entire nut out of the body instead of twisting out of the nut, anyone know were to find new body mount nuts like that or another way to fix it?
Post Post subject: Re: Fender nuts??
Posted: Tue Jun 22, 2010 04:31 AM
You have a few choices. You can either find a donor VW to cut them out of and weld them in your car, or just buy some 8mm x 1.25 nuts and weld them to a piece of flat stock and then weld that to the car, OR the eay way out is to buy some self tapping sheet metal screws and put them right next to where the missing nut is.
cyberjaw4
cyberjaw4
Posted: Tue Jun 22, 2010 05:47 AM
how well does the sheet metal screw way hold up in the off road world and what size should one use and washer or no washer??
Posted: Tue Jun 22, 2010 07:23 AM
I have used 1/4 inch self tappers in the past with a fender washer. It holds up pretty well.
No new posts Projects and Builds My 70' Full Fender Baja Project 1 McKenna 4208 My 70' Full Fender Baj...
 Mon Aug 18, 2014 09:57 PM
McKenna View latest post
No new posts VW Volkswagen & Baja Bug General Discussion What size are fender bolts? 2 az350x 2781 Re: What size are fend...
 Thu Dec 02, 2010 11:30 PM
az350x View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Marks nuts and bolts on westside-- 3 Brettucks 2549 Marks nuts and bolts o...
 Sat Jan 30, 2010 06:18 AM
Brettucks View latest post
No new posts VW Volkswagen & Baja Bug General Discussion stock fender question. 5 Jordynarz 2241 Re: stock fender quest...
 Fri Apr 13, 2007 06:44 AM
