Latest: thelataviayoung
Overall: 3584
Visitors: 142
Total: 142
08: Event Calendar
20: Home
24: Event Calendar
36: Pictures
41: Event Calendar
50: Event Calendar
65: Pictures
70: Home
75: Event Calendar
84: Home
90: Home
94: Event Calendar
112: Home
117: Home
118: Event Calendar
126: Home
130: Pictures
136: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- swing and irs torsion
72BajaBen
72BajaBen
Post Post subject: swing and irs torsion
Posted: Tue Oct 24, 2006 07:14 AM
so i saw over on STF a question, and i was wondering the opposide. I have an IRS tranny, lets saw for some reason i wanted to put a swing on there, would i just have to take the trailing arms off, replace the spring plates and use a swing axle tranny? can the same toraion bars be used? is it even the same torsion?
what im getting at is ....when i get around to building my rail ( probably more later than sooner) can i just find one with a IRS torision housing on it and use a swing if i wanted to make a class 9 buggy. or is it all different.
Post Post subject: Re: swing and irs torsion
Posted: Tue Oct 24, 2006 07:20 AM
You will need swing axle spring platesand matching torsions or cut IRS spring plates and matching torsions.
bajasam96
bajasam96
Yes, But you will need new spring plates too, and I am not sure if the spline is the same for the tortion bar... But I do know it has been done. I know a guy who liked the lean-in tire look of a lowered bug so used a swing setup in a 72
72BajaBen
72BajaBen
Posted: Tue Oct 24, 2006 07:37 AM
sweet this way i can do either if i wanted, and i can widen my search for rail frames
cactusdog
cactusdog
Posted: Sat Oct 28, 2006 08:20 AM
I converted my 65 to IRS, the bad thing is that torsion sticking out makes 31" tires not an option. I found with irs torsion I could get more travel do to the longer torsion,wasted two sets of short swing axle torsion. Now I went back to the shorter swing axle torsion,but installed a set of airbags to take up the load,and set the torsion vary light. Now I'm not over twisting,and can adjust. They track much beter also,the air keeps them tires on the ground
72BajaBen
72BajaBen
Posted: Sat Oct 28, 2006 09:15 AM
i have 31" tires on my car
Posted: Sat Oct 28, 2006 05:31 PM
I run 31's with swing in my 59.
No new posts VW Volkswagen & Baja Bug General Discussion Coils Ver Torsion bar 12 Darn_Near 6744 Coils Ver Torsion bar
 Wed Oct 21, 2015 06:29 PM
thing View latest post
No new posts Projects and Builds Swing Axle Dual Shocks 2 dave46 4074 Re: Swing Axle Dual Sh...
 Fri Sep 11, 2015 08:06 PM
dave46 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion needed asap swing axle trans 5 Dirtjunkie 2788 needed asap swing axle...
 Fri Oct 12, 2012 06:10 AM
No new posts VW Volkswagen & Baja Bug General Discussion Rear torsion housing adjuster 3 ghettodish 4642 Rear torsion housing a...
 Fri Jul 01, 2011 12:44 AM
No new posts VW Volkswagen & Baja Bug General Discussion swing to irs 1 Luckyvw13 1801 Re: swing to irs
 Wed Apr 27, 2011 03:56 AM
