Visitors: 114
Total: 114
26: Event Calendar
29: Event Calendar
82: Event Calendar
90: Pictures
104: Event Calendar
1 2 3 ... 43 44 45 ... 103 104 105
Posted: Sat May 01, 2010 04:14 AM
Friday I made mounts to attach my Hi Lift jack to the front of the rail. I also added mounts for a 20 cal Ammo can. They are the perfect size for quarts of gear and engine oil. Today I took it to Cotton Wood Canyon and tested the new mounts to make sure they hold for Sundays ride.
jone$yyy
jone$yyy
Posted: Sat May 01, 2010 06:03 AM
looked at and said this is really making me angry
then i worked on it
put in a new roller pedal
duct taped some wires
looked at it some more
and said hmm lets get that switch out
but only have a 27 mm and i need a 25 or 26 mm
so i shall get that tomorow before work
then get a new switch and i hope and pray that it works
Billy
Billy
Posted: Sat May 01, 2010 06:14 AM
This work was done recently:
Repainted exhaust with heat resistant paint.
Finished making my metal rear fenders and painted them.
Next:
Getting the rest of the parts I need for engine test stand from CL
Begin removing the rear suspension and transmission for replacment
Posted: Sun May 02, 2010 02:03 AM
The wife and I drove it to the local beer & hot wing joint. Cool
Posted: Sun May 02, 2010 05:05 AM
I been BUSY!!! All steering linkage hooked up, seats mounted in final position, radiator mounts made and installed, sub-frame and bumper ready for powder coating, and mocked up a rear wing. Check it out in the Projects & Builds.
jone$yyy
jone$yyy
Posted: Sun May 02, 2010 06:29 AM
replaced ignition switch and key cyclinder
tomorow before work going to put new and proper fuses back in and see and hope and pray for the best
if not i have no idea what im going to do
Baja_Blue
Baja_Blue
Posted: Sun May 02, 2010 08:26 AM
Got an IRS trans today!!!
Now I have all the parts for the swap just need to weld in some pivot boxes and get the trailing arms off the IRS clip
Matthew 5:14-16
v-duben
v-duben
Posted: Mon May 03, 2010 02:30 AM
wired up some hella 500s and completely wired up my head unit and speakers got the bugs out of the head lights lows and highs i am so stressed i hate wiring i will rip a motor apart no problem but i will cringe at a simple wiring job
02275cc scat performance volkstroker ,EMPI oil cooler,wide shocks by kyb, Flame Thrower Electronic Volkswagen Ignition fan kit Dual weber 44 IDF carbs ,baja kit, gas adjust Kit,ligthened flywheel,performance cluch ,2.5in droped spindels
i love going fast!!!
fast_1
fast_1
Posted: Tue May 18, 2010 12:00 AM
I did a crappy repaint on my front wheels, and wrestled a mostly full 22 gallon fuel cell out of the back seat area and drained it.
Freeloader587
Freeloader587
Posted: Tue May 18, 2010 01:05 AM
made it so key no longer shocks me when i start it and unjammed my throttle cable
jone$yyy
jone$yyy
Posted: Tue May 18, 2010 06:59 AM
replaced bolth axle nuts
looked at the breaks and adjusted
bleed them
got to replace master cyclinder so that should be fun
and it was spooing oil all over the place from the hole in the oil filler thing
so i plugged that up real good
and cleaned all the oil off the exhaust
then parked it.....
Posted: Sat May 22, 2010 06:39 AM
Painted my rear bumper to match the front bumper and interior (Rust-o Hammered Black) also Re-Painted my exhaust, will post exhaust pics tomorrow.
Also painted my ALT Pully, forgot i did that 'till i was looking at the pics and noticed it Rolling Eyes i'm losin' it apparently Laughing Painted Pully shown in "AFTER" pic
BEFORE:
AFTER:
baja17
baja17
Posted: Thu May 27, 2010 05:42 PM
re doin the entire rear suspension today new bushings allround
new drums and shoes in rear
new pads up front along with cut and turn front rotors
vindeta
vindeta
Posted: Thu May 27, 2010 06:05 PM
i finished putting herculiner on my whole car.. now im covered in the stuff.
body off restoration took forever to get done. now im starting to put the whole car back together!!
Baja_Blue
Baja_Blue
Posted: Sat May 29, 2010 07:38 AM
I was scraping that stuff out of my nails and skin for like a week after I used it haha Laughing good stuff though!
Matthew 5:14-16
5 Admin_AzBaja 8355 Baja Bugs on Wiki need...
285 MusicManiac 255402 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 1217 FREE VW BAJA'S
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 2022 Re: Had to go play in ...
0 Northmountainauto 2182 Shop Baja
