Visitors: 90
Total: 90
19: Event Calendar
84: Event Calendar
89: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Modification to Kadron Carbs for Off-Road & Better Breathing
The following users give thanks for this topic perrib - Fri Apr 23, 2010 03:33 PM
Post Post subject: Modification to Kadron Carbs for Off-Road & Better Breathing
Posted: Fri Apr 23, 2010 04:08 AM
So I've been working on a custom set of carbs for a buddy off mine in SoCal. I swapped out the venturis with larger ones, re-jetted it for 1835 with 110 cam, and have been working on a couple of designs for flow improvement for the larger displacement, and venting the float bowls, similar to what some of the off-road guys have been doing to prevent flooding in the really rough stuff.
The goal was to get the bracket for the air cleaner mount out and away from the carburetor throat, where it restricts the flow. After looking at one guy's goofy idea of sending all-thead up through the air cleaners, and taping up the existing hole, I thought I could do better. I modified the existing bracket a bit, added steel tubing and stainless screws to effectively shim the bracket upward. Then, after thinking about a photo dustymojave had posted about a year ago, and again thinking about the way I've seen other off-roaders do it, I decided I'd use steel tubing, and weld it to my air cleaner bracket.
It came out pretty sweet, I think. I'm going to start offering it as an option on my future Kadron kits:
Post Post subject: Re: Modification to Kadron Carbs for Off-Road & Better Breat
Posted: Fri Apr 23, 2010 03:33 PM
Nice mods.
Posted: Fri Apr 23, 2010 08:28 PM
Thanks perrib. Obviously, I had to shorten the stock air cleaner mounting rod and die new threads on it. I also added a wingnut with a flat washer to it, and a rubber seal. The flat washer on the bottom side of the wing nut has a groove cut in it for an o-ring, so I'll probably go that route in the future. Here's another photo (bad lighting) of just the "Hi-Flo" mod with the new wing nut. and seal:
Brettucks
Brettucks
Posted: Fri May 07, 2010 10:58 PM
did you have to drill out the carb body to fit the overflow extension? and what size is the tube??
Posted: Sun May 09, 2010 06:25 PM
Nope The tube is a prefect fit. It's 5/16" ID steel tubing.
Posted: Wed May 19, 2010 06:35 AM
I still claim "Patent Pending" on the idea...LOL
vindeta
vindeta
Posted: Thu May 27, 2010 11:21 PM
i still want a set of those 57baja Smile once i get the car running ill be pm'ing you.
looks awesome btw.
Posted: Fri May 28, 2010 02:26 AM
I know I've shipped at least two so far to AzBaja guys. Caversmoon was one. I can't remember who else got a set. Lots of SoCal guys are using them. They work really well!
Actually, I must say, I "borrowed" the idea from Richard. I redesigned it, improved it, and mated it to my Hi-Flo kit.
6 AZOffroadSwapmeet 2466 AZ Off-Road Swap Meet
 Fri Dec 09, 2016 03:37 PM
No new posts Events and Get Togethers World Wide Annual 400 Miler Off Road Run/Campout May 16-17th 6 azdesertrat87 4936 Annual 400 Miler Off R...
 Tue Feb 09, 2016 04:23 AM
No new posts Projects and Builds When Off Road Racing Was... 4 wideopenmotorsports 4570 Re: When Off Road Raci...
 Sun May 10, 2015 12:35 PM
No new posts VW Volkswagen & Baja Bug General Discussion Baja Bug Modification question 4 Ailill 6198 Baja Bug Modification ...
 Mon Apr 13, 2015 04:07 AM
Ailill View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Dual carbs 11 sandbuggy 6464 Dual carbs
 Sun Jul 14, 2013 02:02 PM
