Visitors: 85
Total: 85
18: Event Calendar
29: Event Calendar
37: Event Calendar
46: Pictures
76: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- intermittent no start
71_Bug
71_Bug
Post Post subject: intermittent no start
Posted: Sun May 16, 2010 09:17 PM
I've been trying to get my 71 to be reliable before I start doing the cosmetic work. For awhile I couldn't even get it started but found out I had wired the distributor and coil backwards. It toasted the pertronix so I went back to points. Then I had an issue where it was running like crap and occasionally would stall, that was found to be a bad vent for the tank. The last time there was so much pressure I had to pry the cap off with my fingers.
The third issue and hopefully the last is sometimes when it is hot either from driving or the Az heat it will turn over for a half to a sec and stop. If I hold the key it will try to engage the starter but sounds like its going to rip the teeth right off the starter. If I turn the key off and then back on I can get another half to a full second and try again. The last time it took about 20 minutes to start. I've replaced the electric portion of the ignition switch, coil, points, rotor, and re-splice any bad looking wires. I dont know if this is related but the distributor has melted the plug that goes through the housing for the points wire.
Any suggestions would be very appreciated
Thanks,
Bob
Baja_Blue
Baja_Blue
Posted: Sun May 16, 2010 11:32 PM
Have you set the timing lately? if it is way over-advanced it will make a sound as if it is grinding the flywheel because the next cylinder is firing before it should
Matthew 5:14-16
71_Bug
71_Bug
Post Post subject: Re: intermittent no start
Posted: Mon May 17, 2010 03:18 AM
right now the timing has been set pretty much by ear. my crank pulley has no markings on it. the grinding comes from holding the key on after it stops turning over. With the key held to the start position for an extra two to three seconds you hear the starter teeth try to engage again
Bob
No new posts VW Volkswagen & Baja Bug General Discussion quick help/won't start 5 Pointvirus 2993 quick help/won't start
 Sun Oct 21, 2012 07:42 AM
Pointvirus View latest post
No new posts VW Volkswagen & Baja Bug General Discussion hard start relay 4 vwboat 2082 hard start relay
 Wed Oct 17, 2012 10:18 PM
No new posts VW Volkswagen & Baja Bug General Discussion Start of a new baja 3 Shorty 2924 Re: Start of a new baj...
 Mon Jul 18, 2011 04:14 PM
23 tdubs-83 11070 Re: Ideas to Start a B...
 Fri Dec 17, 2010 07:23 PM
DeathBug View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Baja wont start 5 pschneider 2048 Baja wont start
 Fri Nov 05, 2010 10:16 PM
pschneider View latest post
