Latest: strike77
Overall: 3575
Visitors: 123
Total: 123
01: My Account
27: Home
34: Home
41: Event Calendar
63: Home
81: Event Calendar
97: Event Calendar
120: Event Calendar
122: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Welding Questions
Welding Questions
Rickman
Rickman
Post Post subject: Welding Questions
Posted: Tue May 11, 2010 12:43 AM
I'm not a welder but would like to learn so I can do some of my own fabrication (very limited), trailer work, etc., not planning on making it a vocation. Just so I can fix some of my own stuff.
Which is easier to learn, MIG or TIG? Which is better?
Without going to community college, any good place that teaches the basics?
Baja_Blue
Baja_Blue
Posted: Tue May 11, 2010 05:23 AM
MIG welding is the easiest to pick up. TIG, from what I've heard, is better
Honestly I wouldn't go spend the money on a class. Have someone who knows how to weld come help you out for a few hours and just weld every piece of scrap metal you have until you got it down, then weld some more haha
That's what I did anyways and look how my welds turned out...
just takes practice practice practice
Matthew 5:14-16
Post Post subject: Re: Welding Questions
Posted: Tue May 11, 2010 03:40 PM
Maricopa County Skill Center is the cheapest and has two very good experienced instructors. I believe Hobart and Miller have videos and HP Books has a book. Welding is a talent that needs lots of practice.
www.mig-welders-tig-we...anuals.htm
Billy
Billy
Posted: Tue May 11, 2010 06:28 PM
I'd practice with some sheet metal you may have lying around. Check youtube, there's bound to be good how to videos. I've been shopping around for a new welder and many Samba users recommended the Hobart Handler 140 mig welder. It's reasonably priced and the pictures a user posted of welds he made were pretty clean. I took a class for welding at a tech college in my area. I spent 8 hours a day running a bead left to right, up and down (etc) on scrap metal and that was the best way to get the hang of it. If you do't already have a welder, save your pennies and buy something of decent quality... or you'll be like me regretting that you didn't Smile
Posted: Tue May 11, 2010 10:53 PM
From what I have read, TIG can make some very nice looking welds that are not as strong as chewing gum. MIG will not be as pretty but easier to make strong when starting out. So it was recommended to me to start w/MIG and when accomplished learn TIG. I bought a decent MIG but have yet to try it out as I want to learn like you.
Billy
Billy
Posted: Tue May 11, 2010 11:32 PM
Penetration is key! Here is a site I found:
www.weldingtipsandtricks.com/
Might offer some insight.
Freeloader587
Freeloader587
Posted: Wed May 12, 2010 12:29 AM
everyone told me clean the surface so you dont get bubbles and brace your self
fast_1
fast_1
Posted: Wed May 12, 2010 04:43 AM
TIG is super hard, but is nice because you can weld more materials such as stainless, and aluminum. I've heard people claim they can weld those with MIG, or have found some special wire that will, but TIG is the right way to do it. For general fabrication purposes MIG is probably the way to go. It's easier, cheaper and with practice you can make pretty good looking welds.
Billy
Billy
Posted: Wed May 12, 2010 07:37 AM
Yes, you will find yourself spending more time prepping your weld area then actually welding. You should be welding clean metal to clean metal. Use a wire brush or wire wheel to clear off any paint or rust. Any foreign things like rust or paint within the metal will result in a weak weld. After each weld chip away the slag with a slag hammer (they're cheap) and clean what is left with the wire brush again (wire wheel at this point would be excessive in most cases. It's best for initial prep). Patience and practice, over and over. Scrap metal is best until you get the feel for it.
Rickman
Rickman
Posted: Wed May 12, 2010 09:28 PM
Been lookin' and I'm leaning towards the Hobart Handler 140 model. Should be enough for what I want to do. Then, figure out how to use it.
Billy: thanks for that link. Pretty informative.
I also found the Millerwelds.com site good too.
Millerwelds.com
Posted: Wed May 12, 2010 11:36 PM
It will work fine. My frame machine was made with a 125 amp welder. 1/2" plate welded to a section of railroad rail.
Rickman
Rickman
Posted: Thu May 13, 2010 04:52 PM
Here's a definite noob question:
When welding on a rail (or any vehicle for that matter), do you need to disconnect the battery? Since you need to attach the clamp on the welder somewhere on bare metal on the frame/body, would the the voltage/amperage from the MIG welder cause any damage to the electricals/wiring?
Posted: Thu May 13, 2010 10:12 PM
It won't hurt Pertronix and voltage regulators. It should be removed since battery acid gas is very explosive. Matco sells a electronics protector that hooks to the battery that allows welding on the new cars with many voltage sensitive control modules thast woluld be ruined by welding.
Billy
Billy
Posted: Thu May 13, 2010 10:56 PM
I don't know if you necessarily have to but if its in question, it couldn't hurt to do.
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 3984 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Simple Questions- Wiring 7 camronbitzer 4756 Simple Questions- Wiri...
 Tue Jul 05, 2016 01:12 AM
No new posts VW Volkswagen & Baja Bug General Discussion Tow Bar questions 3 ghs215 1857 Tow Bar questions
 Mon Nov 16, 2015 02:45 PM
No new posts New Members New Guy Questions 6 Apoc 3696 New Guy Questions
 Wed Jun 19, 2013 01:17 AM
Apoc View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Outdoorsman Questions/Outback vs Squareback 10 Grunt-0341 7480 Re: Outdoorsman Questi...
 Sat Oct 27, 2012 07:07 AM
Grunt-0341 View latest post
