Visitors: 180
Total: 180
24: Pictures
36: Pictures
69: Pictures
70: Pictures
115: Event Calendar
143: Pictures
162: Baja Forums
170: Baja Forums
171: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Ball joint issues
Ball joint issues
ChuckD
ChuckD
Post Post subject: Ball joint issues
Posted: Fri May 07, 2010 11:49 PM
I need some guidance on removing the ball joints from the torsion arms. Shes a 69, cut and turned. Ive got a pickle fork and quite a few hammers. I was able to remove one ball joint from the back of the brake assembly, but not the lower one.
AND, I supposedly have a "bent trailing arm" in the rear. Any help on properly diagnosing that would be great...
Thanks
ChuckD
Brettucks
Brettucks
Posted: Sat May 08, 2010 01:13 AM
Never dealt with the vw 'double ball joint' front end- just used to the american stuff-
Billy
Billy
Posted: Tue May 11, 2010 06:45 PM
No suggestions for the front end, but if you have a bent trailing arm in the rear, it should be easily noticeable. Which one is apparently bent? Compare it to the other prospectively 'unbent' one and note any differences. Does the rear seem to be handling different under driving conditions? How?
ChuckD
ChuckD
Posted: Tue May 11, 2010 07:14 PM
Unfortunatley she rode like crap before AND after this apparent bending occurred. A bent trailing arm is just Theory B. Theory A was a bent stub axle, but that turned out to be straight (or at least it was to my untrained eye).
Billy
Billy
Posted: Tue May 11, 2010 07:30 PM
Can you post photos of the trailing arms?
ChuckD
ChuckD
Posted: Tue May 11, 2010 07:35 PM
Sure. Although I did stare at it for a solid hour or so with a tape measure. The easiest way to see whats wrong is with the tire on, simply because its so pronounced (about 6-8 degrees of positive camber).
Ill take some today or tomorow if its not raining.
Billy
Billy
Posted: Tue May 11, 2010 07:39 PM
Ya there should be no camber if it is a 69, it should be IRS (I could be wrong but I'm pretty sure IRS started in 1968 on the autostick transmission models).
ChuckD
ChuckD
Posted: Tue May 11, 2010 07:55 PM
You are correct sir. Somewhere 3/4s of the way thru 68. I may not know how to do the complicated stuff, but like the good, broke college student i am, i know the numbers.
Billy
Billy
Posted: Tue May 11, 2010 09:23 PM
Haha I'm with you there. Lets see some pics and see if we can figure this out.
Baja_Blue
Baja_Blue
Posted: Wed May 12, 2010 06:39 AM
What did you do that you think bent it?
Stock trailing arms are not the toughest ever but you really gotta romp on them to make them bend.
Did you try loosening the spring plate bolts? I was reading a little while ago on here someone else was having positive camber issues with their IRS set up and it just ended up being the spring plates were out of line
Matthew 5:14-16
ChuckD
ChuckD
Posted: Wed May 12, 2010 07:39 AM
Interesting. I Came back from san Felipe and noticed wuite alot of positve camber. Although I did ride her a little rough, at first I thought i bent the Stub axle. After i dismantled it, I asked the forums, and ive been trying to figure out if i could tell if the trailing arm was bent.
SO, would you happen to have that link to that page on the spring plates?
Baja_Blue
Baja_Blue
Posted: Wed May 12, 2010 07:55 AM
My bad, I found the posts and I think it was an issue with the 3x3 trailing arms not lining up with the spring plates, could still be the issue though.
Also make sure your torsion housing isn't bent
www.azbaja.com/ForumsP...e+boy.html
Matthew 5:14-16
ChuckD
ChuckD
Posted: Wed May 12, 2010 08:04 AM
Thanks man. This is starting to sound expensive...
Baja_Blue
Baja_Blue
Posted: Wed May 12, 2010 08:06 AM
could be, hopefully its something simple like spring plates out of place or just a trailing arm that needs to be replaced
Matthew 5:14-16
No new posts New Members Air filter issues
Can't keep the Dust out
11 DerekT 4878 Re: Air filter issues
 Mon Oct 03, 2016 01:59 PM
No new posts VW Volkswagen & Baja Bug General Discussion Motor issues 12 Dirtjunkie 4799 Re: Motor issues
 Mon Sep 19, 2016 09:06 PM
Really bad issues
4 Pointvirus 2553 Clutch Issues
 Mon Dec 03, 2012 06:33 PM
No new posts VW Volkswagen & Baja Bug General Discussion Wide Ball Joint front end? 5 Darn_Near 7956 Wide Ball Joint front ...
 Wed Sep 07, 2011 08:12 AM
Darn_Near View latest post
No new posts Events and Get Togethers World Wide Joint TRAl and USFS event and ride. 0 perrib 1986 Joint TRAl and USFS ev...
 Mon Jan 31, 2011 03:51 AM
