Visitors: 92
Total: 92
13: Event Calendar
52: Event Calendar
72: Event Calendar
78: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Replacing exhaust
Replacing exhaust
pschneider
pschneider
Post Post subject: Replacing exhaust
Posted: Thu May 06, 2010 05:34 PM
So in the bottom right hand corner of this picture you can see how my exhaust has that little extra metal tube bolted on there. Every picture I have seen of after market exhausts dont appear to have a place for that to bolt onto. Am I mistaken? I dont want to drop a bunch of money on an exhaust and have it not work. I have just been looking at the standard 1 1/2 u-bend exhausts.
Thanks
Freeloader587
Freeloader587
Posted: Thu May 06, 2010 05:46 PM
at least somone knows what it is
this looks like what you got
www.jbugs.com/product/...Code=10023
Last edited by Freeloader587 on Thu May 06, 2010 06:17 PM; edited 1 times in total
Rickman
Rickman
Post Post subject: Re: Replacing exhaust
Posted: Thu May 06, 2010 06:14 PM
Isn't that for the pre-heat for the carb/manifold?
Billy
Billy
Posted: Thu May 06, 2010 11:15 PM
Yes it is. If running dual carbs, you do not need this and the dual carb kits will usually come with a metal plate to cover them.
pschneider
pschneider
Posted: Fri May 07, 2010 01:27 AM
so will I need to buy a special exhaust set up for single carbs? The header freeloader posted looks like exactly what I need but I would prefer to buy the whole exhaust as one unit.
pschneider
pschneider
Posted: Fri May 07, 2010 01:30 AM
I might be mistaken, it seems like a fair number of them are set up for single carbs. thanks for the help and the link, they seem to have some good stuff.
cperry2704
cperry2704
Posted: Mon May 17, 2010 12:32 AM
i had the same problem with my new exhaust, i just cut the flanges off the old exhaust, drilled a small hole in the new exhaust, welded a small piece of pipe in between...problem solved
Posted: Mon May 17, 2010 12:37 AM
You'll be hard-pressed to find an aftermarket off-road exhaust that is set up for intake heat. Most just run without it, although in cooler weather you'll wish you had it, as your engine will bog when you get intake icing. By "cooler" I mean about 60* and less.
No new posts VW Volkswagen & Baja Bug General Discussion Exhaust 7 sandbuggy 3155 Re: Exhaust
 Sun Nov 17, 2013 12:15 AM
No new posts VW Volkswagen & Baja Bug General Discussion thunderbird H4207 - 4 Pipe Chrome exhaust
question for owners/ viewers of particular exhaust
13 beachmaster 6895 thunderbird H4207 - 4 ...
 Tue Nov 29, 2011 01:57 AM
beachmaster View latest post
No new posts VW Volkswagen & Baja Bug General Discussion VW baja bug Exhaust options? 4 71VeeDub 6762 Re: VW baja bug Exhaus...
 Sun Nov 27, 2011 03:23 AM
No new posts VW Volkswagen & Baja Bug General Discussion Replacing air filter
Breather tube?
3 pschneider 3369 Re: Replacing air filt...
 Sun Jun 13, 2010 04:03 PM
Rickman View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Difference between exhaust systems?
competition vs standard?
3 pschneider 2108 Difference between exh...
 Mon Apr 19, 2010 09:32 PM
Freeloader587 View latest post
