Latest: Smokey4
Overall: 3593
Visitors: 85
Total: 85
08: Home
28: Pictures
41: Event Calendar
50: Contact Admin
62: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Charcoal canister?
Charcoal canister?
71_Bug
71_Bug
Post Post subject: Charcoal canister?
Posted: Sun May 02, 2010 11:45 PM
underneath the trunk on my 71 standard I have a black canister that sits on the left side. Their are 1/8 in hoses going from the tank and the fuel overflow hose to it. Air will not go in through the canister. Is this a charcoal canister for the fuel vapors and do I need it. When I pull the cap off the tank it has a lot of pressure behind it and I was wondering if this could have something to do with it.
Bob
Billy
Billy
Posted: Mon May 03, 2010 02:02 AM
That's just an emissions filter. I had one on my '74 but trashed it.
From a post on the Samba:
"The canister is there for emissions purposes...having a working system really has no affect on engine performance, and prevents raw gas fumes from venting to the atmosphere."
71_Bug
71_Bug
Post Post subject: Re: Charcoal canister?
Posted: Mon May 03, 2010 05:08 AM
did you just re route the sm hose from the gas tank to the filler over flow?
Bob
Billy
Billy
Posted: Thu May 06, 2010 06:08 PM
I'm really not sure how you would do it to retain the stock tank- I replaced my tank with an after market one and just ran fuel hose straight from the tank to solid fuel line, nothing else.
Posted: Fri May 07, 2010 02:37 AM
I used on my '66 a canister from a '85 Rx7 that I parted out. Took all the fuel smell out of driving it. Smile
VIN70
VIN70
Posted: Sat May 08, 2010 05:19 AM
Bob
yes, and get rid of all the small lines, (1/4"ish), except the vent hose.
which is on the left front of the tank. originally it goes to a hardline, behind the right front tire, under the pan, then to the rear of the car. usually that line is plugged. if you cant unplug it, just vent it under the car somewhere.
VIN70
VIN70
Posted: Sat May 08, 2010 05:20 AM
Bob
71_Bug
71_Bug
Posted: Mon May 17, 2010 05:08 AM
[quote="VIN70"]
I could find the back end but haven't found the front end of the hardline. It's now vented under neath and seems to be a lot better. no prying off the fuel cap.
Thanks for your help
Bob
