Visitors: 147
Total: 147
02: Pictures
23: Event Calendar
27: Pictures
32: Event Calendar
54: Home
59: My Account
79: Pictures
90: Event Calendar
110: Pictures
134: Pictures
Baja Ghia
1 2 3 4 5 6 ... 9 10 11
Post Post subject: Baja Ghia
Posted: Wed Feb 24, 2010 06:41 AM
i have those same disconnects in my rear bumper and it makes it so much easier to pull off then removing a bunch of bolts holding it to the firewall/cage. car is looking fantastic!
Posted: Wed Feb 24, 2010 06:46 AM
Thanks JW, the connectors really seems to give a good solid connection that's for sure. I still have to put some in the back cage as well. That will be next after I get the steering hooked up.
Posted: Wed Apr 21, 2010 07:14 AM
Wow, didn't realize it has been almost 2 months since I have posted an update, although, don't really feel like I have got much done. I did finally get the seats mounted and can turn the front wheels with the steering wheel. Felt like that was a big accomplishment. Working on getting the radiator mounted now, and will move on to the pedals this weekend. Updated pics to follow in a few days.
Posted: Sun May 02, 2010 04:28 AM
Time to update the progress on the Ghia. As mentioned in the previous post, I was able to get the Seats mounted in thier final positions, and got all the steering hooked up. That was a challenge!
Also cut out the area to mount the rear tail lights. I think this will look really good. I really wanted to incorporate the stock lights into the design, and I think this will work good. What do think?
Next was getting the mounts made for the radiator. The original plan was to mount this in the front, but that proved to be too much of a pain, so came up with this. I will be running a fan underneath, so should still get enough air.
Posted: Sun May 02, 2010 04:32 AM
Then I just had to push it out of the garage and get some photos. My daughter is the model, she can't wait to take it for a drive.
Posted: Sun May 02, 2010 04:46 AM
Yesterday and today I spent some time working on the rear wing mock-up. Got some posterboard and some wood sticks, and came up with this. Looking for some input here. I have a couple ideas to make it a little less "box like" but other than that, I think I like it. How about those tail lights? Opted for some Bus lights here, thought it would be a cool touch.
Then, I took the front all apart. Finished all the welding on the front sub-frame and the bumper. Also made a front skid plate and added some lateral bracing between the front beam horns.
Now have both the bumper and front sub-frame ready to get powdercoated.
jone$yyy
jone$yyy
Posted: Sun May 02, 2010 06:30 AM
dang!!!!!!
that thing is going to be so wicked when you are all done with it
AZsandaddict
AZsandaddict
Posted: Sun May 02, 2010 06:48 AM
sick as hell. Twisted Evil
Posted: Tue May 04, 2010 03:44 PM
To tell you the truth I would skip the wing, Think it looks ugly... I work on some sot of scoop to pull air down into the radiator.
Posted: Thu May 06, 2010 12:29 AM
From "Sick as Hell" to "I think it's ugly" lol gotta love it. To be perfectly honest, I'm still on the fence about the whole thing. I don't like it as it is, but would like to have something there. I had thought of the scoop, at a minimum thought I would open up the top area as a grill. I think from here I will do two things, first I'm going to wait until I get the front back on the car so I can see the whole thing, second work on getting it smaller and more rounded to match the car. Looks too much like a carboard box on a beach ball right now. Anybody do any photoshop? I'm not very good at it but would definately entertain some ideas.
Freeloader587
Freeloader587
Posted: Thu May 06, 2010 12:59 AM
this but flipped the other 180degrees the other way and the part above the tail lights hollow on the body and the current front on the bars.
ideas are hard to convey when not standen there
fast_1
fast_1
Posted: Thu May 06, 2010 01:31 AM
That seems like it would be tough to fab up...
My first thought was too round it a bit, and up the air flow. It looks similar to something that you would find on a rail. Which of course, by nature are quite boxy. Whereas the Ghia has tons of curves. Here's an idea that keeps the same basic shape but accentuates the curves, and would get more air flowing around the radiator. (The grayed out area would be removed)
I thought angling it up more, to make it more aggressive might look good, but that kills visibility. Also, license plate locataion will be tricky with this setup... I think finishing the front and what not is the the best call. Good luck! I can't wait to see where this goes.
Baja_Blue
Baja_Blue
Posted: Thu May 06, 2010 06:42 AM
ehhh not liking the boxy wing... possibly do something more like this....
Matthew 5:14-16
Posted: Sat May 08, 2010 03:56 PM
Shorten the wing to about half the length it is currently, just to cover the radiator. The current wing looks out of place. If you do it more like what baja blue suggested it would look a lot better.
Posted: Fri May 14, 2010 07:23 PM
from the side it looks like a small pickup bed. The car is so round it flows then you have a Box...Not usre on what to do. The smalller wing thing might work.
5 Admin_AzBaja 7119 Baja Bugs on Wiki need...
1568 mufasavnvmc 1012507 Re: what did you do to...
285 MusicManiac 244441 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 290 FREE VW BAJA'S
0 Northmountainauto 1696 Shop Baja
