Latest: BlackIrish05009
Overall: 3574
Visitors: 147
Total: 147
07: Pictures
12: Event Calendar
39: Event Calendar
54: Event Calendar
65: My Account
71: Event Calendar
87: Event Calendar
94: Event Calendar
95: Event Calendar
117: Event Calendar
134: Event Calendar
138: Home
146: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- pedal assembly brake thing
jone$yyy
jone$yyy
Post Post subject: pedal assembly brake thing
Posted: Sat May 01, 2010 07:33 AM
the thing you put in the rubber thing that goes into the main brake thing
is it suppose to slip on and off
cause i noticed when i took it out it leaked a bit of fluid out and didnt know if it was normal
and if now that i took it all apart and out
then put it back together and back into the car
should i bleed the breaks when i get it running again and do a hole break job which i have planned to do
just wondering if thats normal
Brettucks
Brettucks
Post Post subject: Re: pedal assembly brake thing
Posted: Sat May 01, 2010 02:56 PM
too many 'things'.. please be more descriptive...
jone$yyy
jone$yyy
Posted: Sat May 01, 2010 07:14 PM
there is a shaft from the brake pedal that goes into a rubber booty whicih goes into the brake resevor
is it suppose to slip in and out
Posted: Sat May 01, 2010 07:55 PM
That shaft is what pushes pressure on the master cylinder and makes your brakes work. The rubber booty is there to keep dust and garbage out of the seal on that end of the master cylinder.
fast_1
fast_1
Posted: Sat May 01, 2010 07:57 PM
If it's leaking you probably need a new master cylinder. It's a pretty easy thing to replace. You may be able to upgrade to a bus master cylinder.
jone$yyy
jone$yyy
Posted: Sat May 01, 2010 09:25 PM
great just another thing to add to the list that needs replaced
what is a rough cost of a new one
fast_1
fast_1
Posted: Sat May 01, 2010 09:47 PM
Depends on your car, at Chirco they're about $30-40 for the common ones. I have the 22mm out of a 50-67 bus and it works really well. I also have upgraded brakes, it might be overkill for your setup. And I am not sure what, if any, modification is needed to install that.
Don't worry, it's really easy to do. Oh yeah, one thing to check is the reservoir, master cylinders don't come with them. When I replaced mine I cracked the cap. I had to duct tape the cap on to drive to the parts store and get a new one. Those are cheap too, under $15.
Freeloader587
Freeloader587
Posted: Sat May 01, 2010 10:35 PM
or you could pretty much use any master cylinder if you can keep it from moving and got your self a flange kit but i wouldn't advise that unless you've done it before
Posted: Sun May 02, 2010 05:14 AM
Just go to BAP and buy the correct one for your VW.
jone$yyy
jone$yyy
Posted: Sun May 02, 2010 06:27 AM
yeah they are 19.99 at auto zone orderd it
and i get my discount so it will be like 15 bucks
then getting new resevors
1568 mufasavnvmc 915972 Re: what did you do to...
1 LittleBaja 1832 Re: Brake Drum 4 to 5
 Sat Oct 03, 2015 04:52 AM
3 LittleBaja 1716 Re: Brake Drum 4 to 5
 Tue Sep 29, 2015 06:08 PM
No new posts VW Volkswagen & Baja Bug General Discussion Brake light switch?? 3 sandbuggy 2662 Re: Brake light switch...
 Sun Nov 17, 2013 08:21 PM
24 vwboat 9436 Re: lifted spindles an...
 Fri Mar 22, 2013 08:58 PM
