Visitors: 125
Total: 125
16: Home
18: Pictures
27: Pictures
31: Event Calendar
38: Event Calendar
44: Pictures
68: Event Calendar
76: My Account
78: Pictures
107: Event Calendar
109: Pictures
110: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- New to Bajas?
New to Bajas?
1 2 3 4 5 6 7 8 9
The following users give thanks for this topic Anonymous - Mon Mar 09, 2009 02:16 AM
Post Post subject: Re: New to Bajas?
Posted: Mon Mar 22, 2010 11:27 PM
uggbugg01 wrote:
new to bajas and cant figure out how to get into the core of the generator to change the brushes......1600cc
Welcome to AZ Bajas Ugg.
This question really belongs in the normal technical question section, but the brushes are accessible through the air vent outlet openings in the cylindrical body of the generator. They are near the pulley end of the generator. The brushes are held in place by the end of a watch-type spiral spring. You just hook the end of the spring and pull it straight outward and slide the brush out. The wire needs to be disconnected by taking the small screw out. DO NOT DROP THE SCREW INSIDE THE GENERATOR!!!! Installation is just the opposite of removal.
shadowkidz
shadowkidz
Post Post subject: New to Bajas?
Posted: Thu Apr 15, 2010 04:17 AM
Im still quite new to the world of baja's and vw air-cooled engines in general. From what I have gathered from my research. I have a 74 Super Beetle, Baja. With a 1600 DP engine. It has a single carb, a webber progressive.
I started a post a week or so ago asking about blinkers. I fixed these problems and now just would like some additional knowledge.
The only gauge I have in the car is a speedo, it has the gas gauge built in it. It has 2 dummy lights, alt and oil.
I was wondering how do you know if the air cooled engine is overheating?
I think I adjusted the carb well enough so it's not lean. My exhaust gets quite hot (Air coming off of it is hot), while the shroud around the cylinder banks seems to stay cool enough. (Im guessing about 160) I didn't do the dipstick check, yet.
I hope there is a forum already in place for this.
Down With American Muscle. GO German Power !
bajachris
bajachris
Posted: Fri Apr 16, 2010 02:09 PM
Hey people! Im kinda new to the vdub world i just finished building a volksrod but found the car to be kinda useless up here in new england so im starting in on converting it to a baja. Should be simple body wise since its already chopped up. Any first time newbie pointers?
minimoto112
minimoto112
Posted: Fri Apr 30, 2010 03:51 AM
hello im new to bajas and i might pick myself up a 1970 bug.the motor runs good and the bodys in good shape. i want to turn it into a baja bug and would like to know what need to get to reach at least 10 inches of travel if not more so it can survive the desert.that would be great if you guys could help me out
its time to kick ass and chew bubble gum............ and im all out of gum
Posted: Sun May 09, 2010 07:16 AM
What area you basing this criteria of 10" of travel on? Class 11 and Class 9 are required to use ball joint front beams with the only mods allowed being replacing the shocks with whatever will fit on the stock mounts and stops. They finish at a pretty high rate for offroad racers.
Peorianscorpion
Peorianscorpion
Posted: Wed Jul 14, 2010 04:20 PM
I'm picking up a 74 bug that I will be over time evolving into a baja bug. Is there anyone in the peoria area that might be of some help as to what I have and what might be the first projects. This will be a daily driver and will get small mods at first and then I will do larger builds on vacation days.
Posted: Wed Jul 14, 2010 04:33 PM
I'm at 47th Ave & Sweetwater, and can assist you in building your Baja.
Give me a call anytime after 5pm. Eric 602-488-9930
Wldcat10
Wldcat10
Posted: Wed Sep 01, 2010 12:43 AM
How's it goin' everyone! I'm new to AZBaja and also new to Everything VW. I grew up goin camping/hunting with my Dad and Grandfather and all their buddies has Baja bugs. So I got my first Baja bug last week. It's a 1970 and has a vw 1600 engine. Runs good, but i would like to find out the regular tune up procedure and where everything is located. Couple things i want to do with it like wire up the lights, replace shocks, and couple other little things. So if anyone can help it will be very much appreciated.
Posted: Wed Sep 01, 2010 01:18 AM
Welcome to AZBAJA. First tools you should get is the correct Bentley manual and the Building Bajas and Buggies book. They will answer 90% of your questions. We should be able to answer the rest. You also have of couple generations of family experience to draw upon.
baja62
baja62
Posted: Mon Sep 06, 2010 06:00 AM
Welcome to AZ Baja!!! Ive only been a member here for 3 weeks and already have a baja thats CLOSE to finished, possibly running tomorrow. There is a lot of great info here and it has helped a lot in finding help on my car! Eric (dirtjunkie) has assisted me in everything so far and has been a HUGE help, including helping with the engine build. I would also be willing to help as this is just a real blast and I, as well as a lot of others on here would LOVE to have more people at the meets and on the rides!!
longtravel
Wldcat10
Wldcat10
Posted: Wed Sep 08, 2010 08:51 PM
Would I be able to find shocks for my baja at autozone or pepboys? I'm just looking for some regular front end link pin shocks. Not sure if I can go to autozone and get them or would I have to go to a specialty shop like chirco or something? Any help is greatly appreciated!
Posted: Wed Sep 08, 2010 09:35 PM
i ahve picked them up at Pepboys in the past.
crickifur
crickifur
Posted: Fri Sep 10, 2010 02:40 AM
You can get stock shocks there... Honestly though, the stock shocks are about $15 a piece, for $30 a piece, you can upgrade to a coil over stock mount shock at BAP. They are much better off road from what I have been told, if I wasnt changing everything on my suspension, I would change to those myself....
AZ_Born_n_Raised
AZ_Born_n_Raised
Posted: Wed Feb 23, 2011 11:17 PM
Hey y'all, I'm currently in the process of getting a 1965 Beetle that's already been converted to a Baja, but I won't know any of the specs till I can get it home and look at it. I've been raised around buggys my whole life, and started driving my grandfathers when I was 6. I've wanted to get ahold of a Beetle for a long time now and I'm stoked that I might get this one. I'll be back with some questions if and when I get it.
Dropkick65
Dropkick65
Posted: Fri Feb 25, 2011 03:14 AM
Dude, you live in Tucson, go to Chirco! For about $130 you can get adjustable coil-over shocks that work great for stock or baja. Talk to Joe, Don, or anyone else over there and they'll get you hooked up. Plus if you're a supporting member you get 10% with the AZBaja.com code. Go to this link www.chircoestore.com/c...gj0s6ggs62 if you want to check em out first.
1 2 3 4 5 6 7 8 9
55 GHOSTRIDER 36189 hello from ghostrider ...
 Sat Apr 29, 2017 06:16 AM
GHOSTRIDER View latest post
[ Go to pageGo to page: 1 ... 10, 11, 12 ]
175 BugZyla.com 78618 BAJAS at SONIC Eastsid...
 Sun Jun 22, 2014 11:36 AM
No new posts New Members New to bajas from Vt. 14 vtbaja 8572 New to bajas from Vt.
 Wed Aug 14, 2013 08:18 PM
No new posts Events and Get Togethers World Wide Bajas, Bugs, and Buggies at Sycamore Creek-March 2nd
55 JWHracing 30559 Bajas, Bugs, and Buggi...
 Sat Mar 09, 2013 07:55 PM
JWHracing View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Full bodied bajas 2 desertbaja 3473 Full bodied bajas
 Sun Aug 19, 2012 05:29 AM
sandfreaks View latest post
