Visitors: 148
Total: 148
32: Event Calendar
36: Pictures
55: Home
64: Home
79: Event Calendar
103: Pictures
116: My Account
119: Pictures
139: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Engine leaking gas while parked...
pschneider
pschneider
Post Post subject: Engine leaking gas while parked...
Posted: Thu Apr 29, 2010 02:58 AM
It seems like whenever I take my 68 beetle out for a spin and park it, the engine will drip gas onto the ground. Any idea what this is? I can take some pictures if it helps.
Thanks
Post Post subject: Re: Engine leaking gas while parked...
Posted: Thu Apr 29, 2010 03:48 AM
pics would help, have you narrowed it down to a certain area it's leaking form? fuel pump? fuel line? fuel filter? carb?
chickenpants
chickenpants
Posted: Thu Apr 29, 2010 04:30 AM
Have you looked for the source? Your own observations would be more useful than some pics I would think. Suggested areas to look at:
- Fuel line connection at left side frame horn
- fuel line between frame horn and fuel pump
- fuel pump
- fuel line to carb
- carb
If there's enough to find on the ground then the source should be easy to find.
Stephen\r\nChandler, Az
pschneider
pschneider
Posted: Thu Apr 29, 2010 09:37 PM
It appears that it is coming out of the fuel pump? (first picture). It also seems like the breather tube (I think) running from the air intake down through the oil down to the ground may also be leaking something. Any advice?
Posted: Thu Apr 29, 2010 09:45 PM
Sounds like bad fuel pump.
That is vent tube, helps the engine "Case" breath. Newer (70's plus) engins use a PVC valve for the same reason. The older the engine (Milage) the more blowby you get, also if you put in too much oil in it you will get the same thing.
Baja_Blue
Baja_Blue
Posted: Fri Apr 30, 2010 06:53 AM
I'm pretty sure losing gas comes from a bad case of lead foot haha Laughing
it could be that you have no hose clamps on the lines going to your fuel pump
for the breather tube what AZBaja said, either getting some blowby or too much oil...Check your oil right after turning off a warmed up engine(that way the oil is running through any oil cooler, external filter, etc.)
Also, do you have valve cover breathers?
Matthew 5:14-16
pschneider
pschneider
Posted: Fri Apr 30, 2010 02:55 PM
what are valve cover breathers? sorry I am new to this. I will also get some clamps on the hoses and check the oil. Thanks for the help so far.
Baja_Blue
Baja_Blue
Posted: Fri Apr 30, 2010 05:20 PM
Look at the valve cover on this rail, see the hose coming from it?
You drill a hole in the side of the valve cover and put a little fitting in there for a hose to attach to
Here is the one I use...
www.chircoestore.com/c...h45d0e3qt1
It basically helps to vent the case pressure to keep oil from leaking, there pretty much mandatory if you have anything bigger than a 1600. My friend built a 1835 and didn't put a breather system on it and literally blew his oil cap off! sounded like a cannon hahaha
Matthew 5:14-16
Rickman
Rickman
Posted: Sat May 01, 2010 12:10 AM
Also on the oil breather fittings on the valve covers, it was suggested to me that they should be installed up higher on the valve covers and preferably on the front side. It depends on the space you have and what tins your using. I would think that having the breather tubes on top of the valve covers would be optimal. These were already installed by the PO.
No new posts VW Volkswagen & Baja Bug General Discussion Engine kit 0 andrewbaja 1142 Engine kit
 Thu Mar 29, 2018 04:13 AM
andrewbaja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Engine Work 5 ghs215 1876 Re: Engine Work
 Mon Jan 08, 2018 12:59 AM
No new posts VW Volkswagen & Baja Bug General Discussion VW engine stand 2 ghs215 2271 Re: VW engine stand
 Thu Jun 01, 2017 10:28 PM
Trevabooooy View latest post
No new posts VW Volkswagen & Baja Bug General Discussion i need some subaru engine assistance with my baja 1 Prayinmantis 2347 i need some subaru eng...
 Mon May 23, 2016 03:06 AM
5 bajabuggy69 4811 Rebuild and engine swa...
 Fri Sep 05, 2014 06:23 AM
spheromike View latest post
