Visitors: 98
Total: 98
10: Home
15: Event Calendar
32: Home
42: Garage
49: Home
72: My Account
94: Home
1 2 3 ... 42 43 44 ... 103 104 105
jone$yyy
jone$yyy
Posted: Sun Apr 25, 2010 05:05 AM
replaced a couple bolts and nuts that were causing a exhaust leak
got to get gas in the car because i ran out on my way home yesterday and pushed 2 miles all the way to my house lol
thought i had enough but guess not lol
Baja_Blue
Baja_Blue
Posted: Sun Apr 25, 2010 08:26 AM
perrib wrote:
Baja_Blue wrote:
Got Crow harnesses!
Nope only Simpson and Diestharnesses. No sense in taking any chances especially if you end up hanging from them. I heard some of the Crows had that great GM feeling.
well...too late now haha
funny you say that I was talking to the guy at ORW and he has ended up hanging upside down with the harnesses I got, he said they held him in great!(or he was just BSing me to sell them) but he races in MDR series
Matthew 5:14-16
Freeloader587
Freeloader587
Posted: Sun Apr 25, 2010 11:19 PM
put new rear wheel cylinders in pads attached the lines and attempted to fix some carb issues didn't work time for a holly
Posted: Mon Apr 26, 2010 12:18 AM
Installed the hoses from the fan shroud to the heat exchangers. Took 'em off a couple months ago to install the heat/air boxes to the rear exhaust, but never finished. Now its warm here soooooo... I'll get 'round to it another time.
Other than that, I just looked at it.
pelg
pelg
Posted: Mon Apr 26, 2010 04:27 AM
valve adustment
jone$yyy
jone$yyy
Posted: Mon Apr 26, 2010 04:54 AM
i went to perris house and he sent my timing and carb
found out i need a vacum advanced distributor
and still have a bad exhaust leak somewhere
Posted: Tue Apr 27, 2010 06:26 AM
I tokk the rail out to Bartlett Lake on a recovery for Wild West Offroad Recovery. A quad went for a wild ride down a steep hill.
jone$yyy
jone$yyy
Posted: Tue Apr 27, 2010 07:12 AM
i was driving into school and hit a speed bump knocked my coil loose and arced it all the way to the front killling all the wire
towed it home 3 miles
and did a valve adjustment to find out the rocker is bent by cyclinder 4
and the rear is tweaked so it is almost impossible to get the vavle cover off but managed to do it any ways
alot of work to do before friday when my step dad comes home or he is going to kill me!!
Posted: Tue Apr 27, 2010 05:37 PM
Just another speed bump in the road of life. Fortuanately the harnesss is visable except for where it passes through the innner and outer rear 12/4 panel. Slit the housing open and you can see if which wires need to be tapped /replaced. You may also have to change the ignition switch.
jone$yyy
jone$yyy
Posted: Tue Apr 27, 2010 09:03 PM
so i took one long wire from the front to the back and put it back on the coil
how would i know if the ignition switch needs replaced
any idea on how to get the key out of the key hole
Posted: Tue Apr 27, 2010 09:26 PM
Move your post back to eng/elec
Posted: Thu Apr 29, 2010 08:20 AM
Baja_Blue wrote:
perrib wrote:
Baja_Blue wrote:
Got Crow harnesses!
BajaBlue, The Crow harnesses are FINE!
Most of the offroad race cars I tech use Crow belts. I have NEVER seen a problem with them. I have a set in my own Baja Bug. 5-points for all 3 seats.
There was a death in a rail at Glamis a couple of years ago where Crow belts were used. One of the shoulder harnesses had some failure of the stitching to the lap belt. They were NOT competition belts and the car endoed HARD at 65mph+. The guy was big, his belts were loose, and his seat failed as well as the bar behind the seat which the shoulder belts were fastened to. It was undersized tube. Check the sticky in the HBBOffroad Forum at the Samba. Crow ceased making that type of belt with the harnesses sewn to the lap belts.
Belts of any brand need to be installed properly. It's pretty late right now, and I have to leave the house at 5:30AM, but I'll try to get back to this to give some pointers on mounting those belts.
Posted: Thu Apr 29, 2010 08:27 AM
PS...On the subject of belts...Simpson has their (o) (o) in a wringer over having been caught with counterfeit SFI labels on some of their products.
I approve of Deist belts though and have primarily used their products over most of the past 40 years on my own cars.
These days, I would recommend Crow or Deist. There are others which are acceptable such as RJS.
Ejbbal21
Ejbbal21
Posted: Thu Apr 29, 2010 06:30 PM
Let's see starting Monday I took off the stock heads off of my 2276 and put on cb 044. I also went from 1 44 weber to dual 44 webers. This thing should should be a screamer now. Does anyone have time today to help me tune dual carbs in the Mesa AZ area? This will me first atempt to do so. I have a sinking tool and that's about it.
chickenpants
chickenpants
Posted: Thu Apr 29, 2010 11:14 PM
That's Impact Racing that has the issues with SFI certification, not Simpson Racing. Bill Simpson lost control of Simpson Racing after the Earnhardt death.
Stephen\r\nChandler, Az
4 Admin_AzBaja 6194 Baja Bugs on Wiki need...
285 MusicManiac 230077 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 421 Re: Had to go play in ...
0 Northmountainauto 1013 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 2914 Baja hiding in Chandle...
