Latest: Curtis
Overall: 3613
Visitors: 147
Total: 147
03: Home
05: Event Calendar
07: Event Calendar
11: Event Calendar
18: Event Calendar
27: Event Calendar
31: Event Calendar
51: Event Calendar
53: Home
54: Event Calendar
74: Event Calendar
77: Event Calendar
79: Event Calendar
86: Home
97: Garage
103: Home
111: Event Calendar
114: Home
118: Event Calendar
119: Event Calendar
124: Home
125: Home
126: Home
132: Home
140: Event Calendar
141: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- slamming or lowering my beetle
jone$yyy
jone$yyy
Post Post subject: slamming or lowering my beetle
Posted: Fri Apr 23, 2010 06:22 PM
i have heard and read so many different thing im not sure what to do.
can you guys give me some ideas on what to do.
Baja_Blue
Baja_Blue
Posted: Fri Apr 23, 2010 08:23 PM
Lol do what I just did. Add a some poundage of roll cage...
And thats still with swing!! time for IRS and some reindexing for me!
Matthew 5:14-16
Posted: Fri Apr 23, 2010 09:32 PM
You might get better answers over at D3 on that one. Here, you're just likely to watch your karma take another nosedive with questions like that! Laughing
jone$yyy
jone$yyy
Posted: Sat Apr 24, 2010 08:16 AM
lol probably will but i thought i would ask
i was talking to a friend and i think when i get 250 bones im going to slam the front
Post Post subject: Re: slamming or lowering my beetle
Posted: Sun Apr 25, 2010 08:55 PM
It is the opposite of raising it. The back is easy you just reclock the torsions and/or use adjustable spring plates. Upfront you can lower it by removing torsion leaves, cut and turn or cut and install adjusters. For the front the best way is to use dropped spindles and a beam adjuster to dial it in. Lowering it much more than an inch negatively affects handling but since without ground clearance you be going very slow for most maneuvers. Smile Get too low in the rear and like the Class 11 racers who go high flipping the rear trailing arms is nescessary to put the camber where it belongs. Where the rules permit the fast road race track VWs move the body down over the suspension. The front beam head gets raised and /or pie cut and the rear gets raised. You can look on volksrods.com for ideas out side the box.
1 suburbangorilla 4709 CONVERTING '71 STOCK B...
 Wed Apr 01, 2015 11:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion big beetle 3 bugzapper 3415 big beetle
 Wed Dec 17, 2014 06:07 AM
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 2893 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
No new posts VW Volkswagen & Baja Bug General Discussion super beetle baja bug 4 vtbaja 5967 Re: super beetle baja ...
 Wed Aug 14, 2013 04:48 AM
No new posts VW Volkswagen & Baja Bug General Discussion Super beetle vs standard baja kit 3 Voiden 3714 Super beetle vs standa...
 Thu Sep 13, 2012 07:35 AM
