Visitors: 96
Total: 96
30: Home
58: Event Calendar
65: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- I really hate my baja right now...
jon6.0
jon6.0
Post Post subject: I really hate my baja right now...
Posted: Sat Apr 24, 2010 02:10 AM
So here I sit. Stuck on the side of the road with an engine that started making noise and lost power. It was just rebuilt less than 100 miles ago. It is cranking over slow and won't fire. It is full of oil, so wtf? My wife is ready to kill me for sinking so much money into something that won't run more than a couple days at a time. I'm pretty frustrated with it as well. I want an Ecotec, but I don't have the money to be doing that until summer is over. This thing is supposed to be my daily driver.
1967 Baja
2005 GTO
2009 Speed Triple
Posted: Sat Apr 24, 2010 03:26 AM
check the tach wire. disconnect the wire from the coil and see what it does. my car has done stuff like this before. It will be going fine and then all of a sudden, nothing. unplug the wire and it fires right up.
Post Post subject: Re: I really hate my baja right now...
Posted: Sat Apr 24, 2010 03:56 AM
How was the oil pressure and oil temp? Tachs have been known to cause ignition problems.
jon6.0
jon6.0
Posted: Sat Apr 24, 2010 03:59 AM
Temp was less than 140. I still need to replace the pressure gauge.
1967 Baja
2005 GTO
2009 Speed Triple
Posted: Sat Apr 24, 2010 04:11 AM
If disconnecting the tach does not cure the slow cranking, you may have lost oil pressure and the engine did a slow sieze.
jon6.0
jon6.0
Posted: Sat Apr 24, 2010 04:13 AM
Is the tach on the + or - of the coil? We just full flowed it. Hopefully it wasn't that.
1967 Baja
2005 GTO
2009 Speed Triple
Posted: Sat Apr 24, 2010 04:15 AM
Tach is on the negative. Just as in just did it and in 10 miles later it quit?
jon6.0
jon6.0
Posted: Sat Apr 24, 2010 04:18 AM
I was driving to work and it suddenly just quit. I tried pushing on the gas and it just wouldn't go. I coasted off the side of the road. It acted just like when my fuel pump wire came off. Except that isn't what happened as the fuel pump is still connected and working.
1967 Baja
2005 GTO
2009 Speed Triple
Posted: Sat Apr 24, 2010 04:28 AM
Just as in just converted to full flow and 10 miles later it quit?
jon6.0
jon6.0
Posted: Sat Apr 24, 2010 04:30 AM
About 50 miles. But yes just done. What's up Perri? You got an idea?
1967 Baja
2005 GTO
2009 Speed Triple
Posted: Sat Apr 24, 2010 04:31 AM
Like I said if it is not the tach, suspect a slow seize from low oil pressure.
jon6.0
jon6.0
Posted: Sat Apr 24, 2010 04:32 AM
What is a slow seize? It still cranks over.
1967 Baja
2005 GTO
2009 Speed Triple
Posted: Sat Apr 24, 2010 04:52 AM
You said it cranks over slowly like it is partially seized.
jon6.0
jon6.0
Posted: Sat Apr 24, 2010 04:54 AM
What about doing the full flow would give it low oil pressure?
1967 Baja
2005 GTO
2009 Speed Triple
Posted: Sat Apr 24, 2010 04:58 AM
Not setting the clearance between the oil pump gears and cover. Too much clearance results in decent cold oil pressure and very low pressure when the engine warms. If your engine is cranking over at normal engine speed this is not the problem.
4 Admin_AzBaja 5578 Baja Bugs on Wiki need...
1568 mufasavnvmc 889966 Re: what did you do to...
285 MusicManiac 215994 Re: Baja sightings
0 Northmountainauto 50 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1107 Baja hiding in Chandle...
