Visitors: 61
Total: 61
07: Event Calendar
16: Pictures
23: Event Calendar
26: Event Calendar
31: Pictures
46: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Can Somone take a picture of there alternator with wiring
seanoflinn1
seanoflinn1
Post Post subject: Can Somone take a picture of there alternator with wiring
Posted: Thu Apr 22, 2010 02:33 AM
No i dont need a conversion kit I have a 77 vw standard beetle came with a 1600cc FI engine with an alternator the fi was all effed so i Got a 71-72 1600cc duel port carb engine but it had a generator so i got a alternator stand and put the alternator in i got the bug with the engine out of it i plugged the wires in where i think they go!
Post Post subject: Re: Can Somone take a picture of there alternator with wirin
Posted: Thu Apr 22, 2010 02:44 AM
I don't know why I thought you needed a Motorola to Bosch conversion diagram. Embarassed
10 guage Red wire goes to B + stud. 18 guage Blue goes to D+ male spade on alternator. Some but not all had a brown wire 18 guage attached to the alternator case for a ground.
seanoflinn1
seanoflinn1
Posted: Thu Apr 22, 2010 03:11 AM
i think thats what im missing any so i just have to ground it then eh?
Post Post subject: Re: Can Somone take a picture of there alternator with wiring
Posted: Thu Apr 22, 2010 03:22 AM
seanoflinn1 wrote:
iv got a stand for my alternator and i hook up the D+ to the battery and the B+ to a blue wire im guessing for the warning light and if i hook the battery up it smokes and stuff i have no idea whats going on
I think that is your problem. While both terminals are fed 12 volts they perform different functions. B+ is hot all the time. D+ supplies 12 volts to the regulator via the alt. light to turn on the regulator. Reg supplies a ground and the light lights up. When the alternator energizes it supplies 12 volts to the alt eliminating its ground turning off the light. The ground is not that important as the ground to the engine through the tranaxle ground strap is larger. My rail charges without a small ground wire to the alternator.
Posted: Fri May 14, 2010 02:04 AM
What have you found out?
seanoflinn1
seanoflinn1
Posted: Thu Jun 10, 2010 09:50 PM
I got this problem fixed no problem just had to ground the alt. But now my bug wont start Sad any ideas?
Posted: Thu Jun 10, 2010 10:12 PM
Don't hold back. No spark?, no crank?, no fuel?
seanoflinn1
seanoflinn1
Posted: Thu Jun 10, 2010 10:54 PM
Have spark it turns and fuel is getting up to the carb and the carb smells of fuel but no fire!
Posted: Fri Jun 11, 2010 02:23 AM
There is an old mechanics saying. If its got gas and spark its gota run. Smile
Maybe its out of time or your fouled the plugs.
Posted: Fri Jun 11, 2010 07:02 PM
Four things to run...Fuel, Spark, Timing and Compression.
seanoflinn1
seanoflinn1
Posted: Sun Jun 13, 2010 05:03 AM
Needle valve in the carb was stuck i got it Smile but now there is another problem New clutch and when the bug is running and i put it in gear and i let out the clutch it makes a big grinding noise it starts to move a little then doesent anymore and makes the noise untill i push the clutch pedal down any ideas?
Posted: Sun Jun 13, 2010 05:09 AM
Stripped hub, broken cv
seanoflinn1
seanoflinn1
Posted: Sun Jun 13, 2010 06:59 AM
so how do i find out if thats what it is and how do i fix it?
Posted: Mon Jun 14, 2010 11:07 PM
Put it in gear and look for the spinning axle.
No new posts VW Volkswagen & Baja Bug General Discussion Simple Questions- Wiring 7 camronbitzer 4513 Simple Questions- Wiri...
 Tue Jul 05, 2016 01:12 AM
Efi to carb
4 bugzapper 1953 Wiring
 Tue Jun 28, 2016 03:16 PM
No new posts Projects and Builds My 64 Baja in the making (Picture Heavy) 10 Fryic 6090 My 64 Baja in the maki...
 Thu May 23, 2013 01:01 AM
Fryic View latest post
No new posts Projects and Builds Little red baja build (picture heavy) 10 blubaron66 7697 Little red baja build ...
 Tue Aug 14, 2012 08:21 PM
hood123 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Its my turn (picture heavy) 7 blubaron66 5282 Re: Its my turn (pictu...
 Thu May 17, 2012 12:24 AM
blubaron66 View latest post
