Latest: BlackIrish05009
Overall: 3574
Visitors: 122
Total: 122
24: Home
25: Home
26: Home
27: Home
38: Home
39: Home
41: Home
50: Event Calendar
55: Event Calendar
95: Home
107: Event Calendar
108: Event Calendar
122: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- clutch ?'s
clutch ?'s
jone$yyy
jone$yyy
Post Post subject: clutch ?'s
Posted: Tue Apr 20, 2010 06:38 AM
so im driving my new v dub all over town today to school in gilbert and then the long treck to mesa everything is going fine and dandy
but when i get back to the valley to get my brother and drop off my friends its all down hill from there.
i get home and it was a little bit hard to get into gear but i thought nothing of it
then i go to circle k to get a drink and it was really hard to get into 1,2,3 rd
so i got some new gear oil put it in same problem
and when i push the clutch in it almost to the floor
so i tried to adjust the clutch to the best of my abilities and nothing changed
so now i wonder if the clutch pressure palte and throw out bearing or something
any ideas
thanks
Post Post subject: Re: clutch ?'s
Posted: Tue Apr 20, 2010 06:40 AM
Something in the clutch system is going south.
jone$yyy
jone$yyy
Posted: Tue Apr 20, 2010 06:44 AM
yeah i figured that but always good to hear it from someone else
thanks
i wish that i was there when you fixed my last one
how hard is it i looked at my book
i figured undo the bolts and nuts mounting to the trans and motor with it on jack stands
then with a block of wood and jack on the lower part of the motor and pull it out
something to that nature
got to remember it is a stock beetle
thanks again perri
Posted: Tue Apr 20, 2010 11:52 AM
sound like you broke a clutch fork.
jone$yyy
jone$yyy
Posted: Tue Apr 20, 2010 06:30 PM
how do you replace that?
and what does it do
Posted: Tue Apr 20, 2010 08:47 PM
and what does it do
motor has to come out. It's the lever that moves the throwout bearing and disengages your clutch. Without it, the clutch stays engaged, so you can't start/stop the car or shift gears.
Is that basically what's happening?
jone$yyy
jone$yyy
Posted: Wed Apr 21, 2010 08:55 AM
yeah but i have no pedal either just goes to the floor so i have no idea
going to do a clutch cable on it read how to do that and do that tomorow
see if that works and hope for the best
if not then i will probably do it or have perri do it not sure yet
but it sounds pretty easy to do and when i drop the motor im sure i will know more and find out whats happening i dont want to mess anything up
Posted: Wed Apr 21, 2010 06:09 PM
When you press the clutch, does the clutch arm on the transmission move or not? That will tell you if the hook/cable broke up by the pedals (arm doesn't move) or if the problem is in the clutch itself (arm does move- time to pull the motor!).
That should be an easy way of at least seeing where you need to look first.
jone$yyy
jone$yyy
Posted: Thu Apr 22, 2010 07:15 AM
yeah i got a new cable in the car today but before the arm would move a bit like 1/2 in tryed time and time agian to adjust it but wouldnt
so i pulled the motor to look at the clutch and what not
looks to be pretty worn so i think im going to do that tomorow
and the arm looks pretty decent
how do you put the spring (coil thing that raps round it) all the way on to the arm
is it pretty easy
jone$yyy
jone$yyy
Posted: Thu Apr 22, 2010 07:22 AM
also how do i know if my clutch forks are good or not and where are they located
Posted: Thu Apr 22, 2010 06:08 PM
Clutch forks are what hold the throwout bearing in place. If the little grooves are hogged out or the arms are not straight, time for a new one.
www.chircoestore.com/c...ts_id=1625
jone$yyy
jone$yyy
Posted: Thu Apr 22, 2010 06:16 PM
yeah i was on chirco and i saw that im going to home and take a peek at it and see if is that but will i have the motor out im going to put new clutch and pressure plate in and all that its a 100 bucks so what the heck and it is in kinda bad shape anyways so im goin to replace it
i will see if it needs a new fork and if not then just do a clutch
thanks guys for all the help
2180 Baja bug with 091 trans.
11 51BUG50 3164 Clutch and pressure pl...
 Fri Mar 10, 2017 08:22 PM
parts
0 bajablastman1214 1803 Clutch
 Sun Aug 16, 2015 05:23 AM
Really bad issues
4 Pointvirus 2286 Clutch Issues
 Mon Dec 03, 2012 07:33 PM
No new posts VW Volkswagen & Baja Bug General Discussion where to find clutch slave install tips/instr.??? 6 bajabuggin 5471 where to find clutch s...
 Sat Sep 11, 2010 02:58 PM
az350x View latest post
No new posts VW Volkswagen & Baja Bug General Discussion my clutch is whining... 11 JWHracing 3280 my clutch is whining.....
 Mon Jun 29, 2009 04:36 AM
danjones333 View latest post
