Visitors: 106
Total: 106
30: Home
45: Event Calendar
74: Drivers
100: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- welding problem...
welding problem...
Brettucks
Brettucks
Post Post subject: welding problem...
Posted: Fri Apr 16, 2010 05:58 PM
Started to practice welding today- had a prob within a minute...
gun stopped feeding wire but reel kept turning. Clipped wire by reel and tried to pull wire back but it broke off. still have wire hanging out of gun side but it wont move and Im afraid of breaking it off..
any suggestions on how to remove wire or prevent this from happening again??
thanks!!
Posted: Fri Apr 16, 2010 06:32 PM
sounds like the gun is twisted up. If its twisted up it will bind and not allow the wire to feed. Make sure too that the hose part of the gun isn't looping around itself.
Brettucks
Brettucks
Posted: Sat Apr 17, 2010 12:29 AM
Took it apart and the tube the wire goes into after the power feed rollers had got pushed in some, letting the wire fold itself in a ball--
working good now- thanks for the info...
Post Post subject: Re: welding problem...
Posted: Sat Apr 17, 2010 02:44 AM
Back of the roller tension spring.
Brettucks
Brettucks
Posted: Sat Apr 17, 2010 05:59 AM
I let it be looser now and went well... seems like the feed dial isnt working well as I had it turned down to 0 and it still fed wire like a firehose--- I will do the throttle bracket but when I get to seat belt tabs Im getting a pro...
The license light bracket is ugly but strong...
-Brett
No new posts VW Volkswagen & Baja Bug General Discussion Trailer Welding? 2 Rickman 2311 Re: Trailer Welding?
 Tue Jan 31, 2012 03:37 AM
No new posts VW Volkswagen & Baja Bug General Discussion I have a problem
Can anyone help me
8 PaDan 5569 Re: I have a problem
 Tue Jul 12, 2011 06:33 AM
Rickman View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Rack and pinion problem
Steering backwards?
5 Bunnyhunny425 5511 Re: Rack and pinion pr...
 Sat Apr 30, 2011 06:38 AM
No new posts VW Volkswagen & Baja Bug General Discussion 1960 vw baja surging/wheel hop problem
baja problems
24 hayduke 9555 Re: 1960 vw baja surgi...
 Wed Aug 04, 2010 02:40 AM
hayduke View latest post
No new posts VW Volkswagen & Baja Bug General Discussion NEW PROBLEM YAY :)
clutch or transaxle
4 seanoflinn1 2449 NEW PROBLEM YAY :)
 Mon Jun 14, 2010 08:51 PM
DONT View latest post
