Visitors: 137
Total: 137
31: My Account
37: Event Calendar
55: Home
56: Home
88: My Account
94: Drivers
103: Event Calendar
130: Event Calendar
137: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- shock setup
shock setup
thext94
thext94
Post Post subject: shock setup
Posted: Sun Apr 11, 2010 12:32 AM
i'm looking at getting new front and rear shocks for my 67 baja. irs rear and ball-joint front end. what are you guys running and do you have any suggestions?
thanks,
tyler
Post Post subject: Re: shock setup
Posted: Mon Apr 12, 2010 03:43 PM
thanks,
tyler
Mine has FOA rear and Sway A Way race runners in frt. There are tons of variables in shocks. How/where/how hard do you drive? Otherwise stock suspension? Budget?
Here is the standard, although stiff frt: www.chircoestore.com/c...ts_id=1095
Matching rear: www.chircoestore.com/c...ts_id=1153
If lifted and the budget is better: www.chircoestore.com/c...ts_id=1153
And goes up from there...
thext94
thext94
Posted: Tue Apr 13, 2010 01:12 AM
i drive the trails in parker, az so mostly hard packed dirt and alot of rocks. i have long rancho shocks in the rear but stock in the front. as far as budget goes, i dont want to drop all my cash on overkill shocks, but i have enough for a decent pair. the front has adjusters in the beam which are cranked up nearly all the way. gonna back them down a bit when i get back there.
Posted: Tue Apr 13, 2010 10:20 PM
For a lifted ball joint, the bilstein class 11 shock would be your best bet.
thext94
thext94
Posted: Wed Apr 14, 2010 06:22 AM
alright sounds good i'll pick some up. thanks again youve been helping out alot haha Very Happy
Posted: Wed Apr 14, 2010 02:16 PM
Will they won't be performance shocks search OKTR6r's post on The Samba he listed oil filled Monroes from a mini van that work.
No new posts VW Volkswagen & Baja Bug General Discussion Rack and Pinion setup on a Baja bug 3 DFWbaja 3709 Rack and Pinion setup ...
 Fri Jan 30, 2015 01:44 PM
No new posts VW Volkswagen & Baja Bug General Discussion Shock Hoops
Wanting to build shock mounts without cutting the body
29 POCman 24330 Re: Shock Hoops
 Thu Nov 15, 2012 07:50 AM
POCman View latest post
15 onthefarm 10979 Number on the shock to...
 Sat Jul 28, 2012 05:03 AM
No new posts VW Volkswagen & Baja Bug General Discussion Baja roof height with 3x3 setup 3 ghettodish 3253 Baja roof height with ...
 Wed May 18, 2011 05:17 PM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion oil cooler setup.. 6 Brettucks 4279 oil cooler setup..
 Tue Feb 09, 2010 02:57 AM
Brettucks View latest post
