Visitors: 269
Total: 269
06: My Account
07: My Account
08: My Account
13: My Account
14: My Account
15: My Account
16: My Account
37: My Account
38: My Account
42: Pictures
44: Pictures
50: My Account
51: My Account
52: My Account
53: My Account
56: My Account
57: My Account
68: My Account
72: Pictures
73: Pictures
75: Event Calendar
91: Event Calendar
92: My Account
117: Home
118: Event Calendar
119: Home
120: Event Calendar
157: Baja Forums
158: Baja Forums
162: Baja Forums
163: Event Calendar
164: Baja Forums
166: Baja Forums
171: Baja Forums
180: Baja Forums
182: Baja Forums
183: Baja Forums
189: Baja Forums
190: AMAZON.com
191: Baja Forums
194: Baja Forums
195: Baja Forums
196: Baja Forums
197: Baja Forums
198: Event Calendar
200: Baja Forums
201: Baja Forums
202: AMAZON.com
203: Baja Forums
204: Baja Forums
205: Baja Forums
206: Baja Forums
207: AMAZON.com
208: AMAZON.com
209: AMAZON.com
210: AMAZON.com
211: Baja Forums
212: AMAZON.com
213: AMAZON.com
214: Baja Forums
215: Baja Forums
217: Event Calendar
218: AMAZON.com
219: Event Calendar
220: AMAZON.com
221: AMAZON.com
224: Baja Forums
225: AMAZON.com
226: AMAZON.com
227: Baja Forums
228: Baja Forums
229: Baja Forums
230: AMAZON.com
231: Event Calendar
232: AMAZON.com
233: AMAZON.com
234: AMAZON.com
235: AMAZON.com
236: AMAZON.com
237: AMAZON.com
238: Baja Forums
239: AMAZON.com
240: Baja Forums
241: AMAZON.com
242: AMAZON.com
243: AMAZON.com
244: AMAZON.com
245: My Account
246: Baja Forums
247: Baja Forums
248: AMAZON.com
249: AMAZON.com
250: AMAZON.com
251: AMAZON.com
252: Baja Forums
253: Event Calendar
254: AMAZON.com
255: AMAZON.com
256: AMAZON.com
257: AMAZON.com
258: Baja Forums
259: Baja Forums
260: Baja Forums
261: Pictures
262: Baja Forums
263: Baja Forums
264: Baja Forums
265: Baja Forums
266: Event Calendar
267: AMAZON.com
268: Event Calendar
269: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Can Somone take a picture of there alternator with wiring
seanoflinn1
seanoflinn1
Post Post subject: Can Somone take a picture of there alternator with wiring
Posted: Tue Apr 13, 2010 04:10 AM
attached please that would be awesome
Brettucks
Brettucks
Posted: Tue Apr 13, 2010 04:21 PM
Most alternators have only two wires, the big screw post goes to 12+ , the spade terminal goes to the warning light. Is yours different?
If so give us more info on it or the problems you are having...
jon6.0
jon6.0
Posted: Tue Apr 13, 2010 05:43 PM
I can tell you from experience if the warning light isn't hooked up and working right it won't charge.
1967 Baja
2005 GTO
2009 Speed Triple
Post Post subject: Re: Can Somone take a picture of there alternator with wiring
Posted: Tue Apr 13, 2010 08:41 PM
DITTO! I replaced my alternator last fall FOR NO REASON! The idiot light was burned out, and the charging system won't work without it. Your speedometer illumination lights are the same bulb.
If you still need a pic, lemme know. It's VERY straightforward. What problem are you having anyway?
seanoflinn1
seanoflinn1
Posted: Tue Apr 13, 2010 09:38 PM
well the thing is I have a bug that came with a fuel injected engine but it was effed so i went and got a carb on from a 72 and it works but i didnt have the voltage regulator so i swaped my alternator and i thought i knew how the wires and hooked up i have a thick red one which comes from the battery and a blue one that is in the same harness are those the wrong wires?
Posted: Wed Apr 14, 2010 04:37 AM
Procedure is on page 7-23 of the VW factory repair manual.
seanoflinn1
seanoflinn1
Posted: Wed Apr 14, 2010 05:08 AM
I do not have that book
Posted: Wed Apr 14, 2010 05:19 AM
Thats what I thought. Your tool box is missing the most important tool.
Posted: Wed Apr 14, 2010 05:36 AM
Did you order it yet?? Chirco has them in stock. I'm giving you this but if you don't give us proof you are the proud owner of a VW Factory Manual within 30 days we might/will give you the -karma treatment. Very Happy
www.glenn-ring.com/temp/gen_alt.gif
jone$yyy
jone$yyy
Posted: Wed Apr 14, 2010 07:32 AM
lol someone else might get the karma treatment instead of me!!!! :}
Posted: Wed Apr 14, 2010 02:13 PM
I asked the member to stop dinging you a long time ago.
Posted: Tue Apr 20, 2010 02:14 PM
Sean
Did that link to the conversion get it fixed?
seanoflinn1
seanoflinn1
Posted: Wed Apr 21, 2010 10:53 PM
iv got a stand for my alternator and i hook up the D+ to the battery and the B+ to a blue wire im guessing for the warning light and if i hook the battery up it smokes and stuff i have no idea whats going on
Posted: Thu Apr 22, 2010 12:08 AM
B+ is battery positive side. D+ is the field wire the small wire. Did you look at the conversion wiring diagram link? It is right out of the VW factory manual.
catchbats
catchbats
Posted: Thu Apr 22, 2010 12:58 AM
Some people are putting LED's on the charging circuit for the warning light. If this is the case, in "most" situations it's not going to work, and won't let the charging system work either! LED's only work on a specific voltage for which they're rated and you have to get the polarity correct as well. Just a heads up to anyone thinking about adding niffty LED's to their dash instruments.
No new posts VW Volkswagen & Baja Bug General Discussion Simple Questions- Wiring 7 camronbitzer 5551 Simple Questions- Wiri...
 Tue Jul 05, 2016 01:12 AM
Efi to carb
4 bugzapper 2765 Wiring
 Tue Jun 28, 2016 03:16 PM
No new posts Projects and Builds My 64 Baja in the making (Picture Heavy) 10 Fryic 6871 My 64 Baja in the maki...
 Thu May 23, 2013 01:01 AM
Fryic View latest post
No new posts Projects and Builds Little red baja build (picture heavy) 10 blubaron66 8712 Little red baja build ...
 Tue Aug 14, 2012 08:21 PM
hood123 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Its my turn (picture heavy) 7 blubaron66 5875 Re: Its my turn (pictu...
 Thu May 17, 2012 12:24 AM
blubaron66 View latest post
