Visitors: 89
Total: 89
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- quick welding question
Brettucks
Brettucks
Post Post subject: quick welding question
Posted: Sat Apr 10, 2010 05:08 PM
No ive never welded on a car before (just welded a little on a bench)
Do you need to disconnect the battery before welding on the car?? I know to get some good spark protection if your in a dangerous area (around the gas tank, upholstery, magnesium engine with oil around it) but not sure if the welder will fry your electronics (grounding to the cage of course)..
thanks-
-Brett
Post Post subject: Re: quick welding question
Posted: Sat Apr 10, 2010 05:55 PM
i would disconnect the battry for safety reasons yes. also if you're welding or grinding by glass, cover the glass or it will pit all over the place Shocked
Posted: Sat Apr 10, 2010 08:31 PM
Yes, disconnect the battery. I would disconnect any module also.
No new posts VW Volkswagen & Baja Bug General Discussion Baja Bug Modification question 4 Ailill 6198 Baja Bug Modification ...
 Mon Apr 13, 2015 04:07 AM
Ailill View latest post
No new posts Projects and Builds Just a quick little project...
56 wideopenmotorsports 44856 Just a quick little pr...
 Sun Mar 08, 2015 12:29 AM
yellowchev View latest post
No new posts Club AzBaja (Arizona Chapter) electrcial quick connections for winch. (DALTON) 7 vwboat 2327 electrcial quick conne...
 Sun Apr 20, 2014 02:42 PM
No new posts VW Volkswagen & Baja Bug General Discussion Question about local vendors in the Phoenix Valley areas 2 Salvo 2130 Question about local v...
 Fri Sep 20, 2013 07:37 AM
Sweetjumps View latest post
No new posts VW Volkswagen & Baja Bug General Discussion homade baja fenders question 9 vtbaja 4532 Re: homade baja fender...
 Mon Sep 16, 2013 06:23 PM
