Latest: Milkmanbryan
Overall: 3583
Visitors: 151
Total: 151
12: Home
36: Home
65: Event Calendar
78: Home
97: Home
118: Event Calendar
132: Home
135: Event Calendar
150: Baja Forums
1 2 3 ... 39 40 41 ... 103 104 105
Posted: Tue Apr 06, 2010 03:00 AM
Found I had a plugged Idle Jet and also a sticky powervalve. After cleaning both, I have very little stuble in the throttle and I think a little more adjustment will take care of it.
Repaired a bolt that was supposed to be holding my voltage regulator, but instead was shorting across it.
Filled with 11.5 gal, didn't think I was going to make it to the gas station. Amazing how it can run with no fuel in the filter. That's my first nearly full tank of gas I've run through it without siphoning it for other uses.
Found my brakes work well enough to lock 3 wheels up when traffic came to a halt on grand today.
cyberjaw4
cyberjaw4
Posted: Tue Apr 06, 2010 05:12 AM
well it started yesterday and will keep going for a few more days but...
i pulled my motor and started my first tear down of a motor ever eather to just rebuild or build it bigger here some pic's cause i know we all LOVE pic's
first day
second day
chickenpants
chickenpants
Posted: Thu Apr 08, 2010 12:46 AM
Replaced tie rods with new reinforced tie rods by Bugzyla, thanks Daryll
Stephen\r\nChandler, Az
Rickman
Rickman
Posted: Thu Apr 08, 2010 01:13 AM
Repaired one of my driving lights on the rail. Mickey moused a water faucet knob on the driver's side cam-release 5-point seatbelts (or spend $150 for replacement). Cleaned UNI filter wrap. Looking for some parts to fix the stripped out carb/manifold bolt.
Posted: Fri Apr 09, 2010 03:56 AM
I adjusted the valves and re set the timing. Heading to Martinez Canyon on Friday.
Posted: Sat Apr 10, 2010 06:27 AM
Took the rail out for its refresher course at the water fall out in Florence. Sorry about the large pictures they are not from my camera.
These steps are where I went down. The view is from the top.
Rickman
Rickman
Posted: Sat Apr 10, 2010 04:39 PM
Cool pics!
Now I don't feel so bad, I thought I drove my rail too rough. Guess not. Smile
Posted: Sat Apr 10, 2010 05:58 PM
i filled my bug with gas! Very Happy
Posted: Sat Apr 10, 2010 11:26 PM
Rickman wrote:
Cool pics!
That was just practice. You should of been with me today. I taught three quads why they should not roll thier eyes and get in front of me. All three nearly crashed trying to out run me through the rocks.
Posted: Sat Apr 10, 2010 11:40 PM
I looked at it and shed a tear she is still full of all the crap from moving, in fact all three cars are still full.
Posted: Sun Apr 11, 2010 12:55 AM
Replaced the battery. Started looking at finishing carpet but remembered I needed adhesive. Oh well, back to the honey-do list..... Wink
DutchBug
DutchBug
Posted: Sun Apr 11, 2010 01:20 PM
Sanding, restoring and shaping fiberglass fenders. Pics soon.
Posted: Sun Apr 11, 2010 03:46 PM
Drained a gallon of gas out of it for the lawn mower and grass dethatcher! Laughing
DutchBug
DutchBug
Posted: Sun Apr 11, 2010 05:49 PM
Oh gosh, the crisis is coming down hard in Mesa Wink
Baja_Blue
Baja_Blue
Posted: Tue Apr 13, 2010 05:43 AM
lots and lots of grinding with a wire wheel on the new IRS rear end. Then I put two coats of primer on, tomorrow will put on a few coats of flat black Cool
Ordered poly trailing arm bushings, CV boots, brake lines, and CV grease.
We'll see what else needs replacing once I pop those drums off
Matthew 5:14-16
4 Admin_AzBaja 6529 Baja Bugs on Wiki need...
285 MusicManiac 237612 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1019 Re: Had to go play in ...
0 Northmountainauto 1322 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 3708 Baja hiding in Chandle...
