Visitors: 224
Total: 224
40: My Account
41: Event Calendar
138: My Account
177: Baja Forums
189: Baja Forums
190: AMAZON.com
195: Links
197: AMAZON.com
198: AMAZON.com
202: AMAZON.com
204: AMAZON.com
205: AMAZON.com
207: AMAZON.com
208: AMAZON.com
209: AMAZON.com
210: AMAZON.com
212: Baja Forums
213: AMAZON.com
214: AMAZON.com
216: Baja Forums
218: AMAZON.com
219: Baja Forums
220: AMAZON.com
221: AMAZON.com
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Earnest's Baja Project
saturnbug
saturnbug
Post Post subject: Re: Earnest's Baja Project
Posted: Tue Dec 22, 2009 09:49 PM
how does the rad do at highway speeds?I have seen the rad mounted up front under the hood before but if it gets good air in the back that would be a easier way to go.
Buggyboat
Buggyboat
Posted: Sun Jan 17, 2010 04:05 PM
This is a way cool bug. I think it said that the rear arms are boxed, and it did not appear that a cage went in. How/where are you going to mount the rear shocks?
Posted: Mon Jan 18, 2010 07:06 PM
I couldn't find the pic in the thread, but he built a rear shock mount in the cabin. Once Daryll sees this he will post up the pic. Cool
jk97
jk97
Post Post subject: Earnest's Baja Project
Posted: Thu Jan 21, 2010 06:35 AM
Nice work. That's is one sweet ride.
Jim
jk97
'66 Berry Mini-T IV
SuburbanLegend
SuburbanLegend
Posted: Fri Apr 02, 2010 04:38 PM
I'm trying to wire up my Ecotec engine and have about a million questions. Here are just two:
1) where did you mount the computer and relays...inside or outside the car? If inside, where you able to seal off the hole where the wire loom comes through? Would it be safe enough outside the car on the firewall?
2) What water temp and oil pressure gauge senders did you use? I'm having a hard time finding the right ones.
Posted: Sat Apr 10, 2010 06:40 AM
You can get the oil temp & oil pressure tread adapter through autometer. It fits on the exhaust side of the motor. The temp sender we just drilled and tapped an 1/8 NPT hole.
vwJ420
vwJ420
Posted: Tue May 25, 2010 05:10 AM
that thing is sexy
J
4 Admin_AzBaja 6292 Baja Bugs on Wiki need...
1568 mufasavnvmc 965070 Re: what did you do to...
285 MusicManiac 232875 Re: Baja sightings
1199 Dalton 317495 My 69 project
No new posts Projects and Builds Project Purple People Eater 4 Yasha7fold 2591 Project Purple People ...
