Latest: ecthemc
Overall: 3567
Visitors: 159
Total: 159
18: Home
31: Groups
63: Event Calendar
157: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- starting back up on my baja bug
cwick1989
cwick1989
Post Post subject: starting back up on my baja bug
Posted: Tue Apr 06, 2010 01:43 AM
I started on my baja a few years ago... rebuilt the engine and did a quick paint job and its sat in my yard ever since so Ive decided to start on it again. so far ive completely ripped out the interior and in the process either patching or replacing floor pans. Any advice on that would be helpful! I have also completely removed the old wiring harness. (well what was left of the old one) and any advice on putting the new one in will be helpful also.. Ill get pics up as soon as I get enough done to take pics on. any advice will be appreciated and if Im doin something completely stupid PLEASE let me know Thanks
Heres some old pics
cwick1989
cwick1989
Posted: Tue Apr 06, 2010 10:29 PM
And here are new pics need advice on interior!
Ok thoughts on the floor? I wanna put the roll or spray in bedliner in it and dont want holes in the floor... So should i replce the pans or try and patch them and is there a way to patch em? Thanks!
ChuckD
ChuckD
Posted: Wed Apr 07, 2010 09:09 PM
Having recently rewired my baja, I can gaurantee that simpler is the way to go. Adding on to a wiring loom is easier that making a bigger and more complicated one. I cry myself to sleep at night knowing that I got carried away, and now its an enourmous pain to try and fix anything electrical.
As for the pan holes, if thier not bigger that a quater, cut some thin pieces of aluminum and bondo that bad boy. Assuming your still going to put the bed liner over that.
Good luck!
Posted: Wed Apr 07, 2010 10:26 PM
looks to me like someone laid some fiberglass on that pan
Baja_Blue
Baja_Blue
Posted: Wed Apr 07, 2010 10:38 PM
nice racing seat...lol Cool
as for the holes just cut a piece of metal and weld it over. if there nothing too major I wouldn't worry about it, from the looks of it there no bigger than quarter size so if all you want to do is fill them then aluminum and bondo will do the job like Chuck said
Matthew 5:14-16
cwick1989
cwick1989
Post Post subject: Re: starting back up on my baja bug
Posted: Thu Apr 08, 2010 07:02 AM
Good luck!
i was actually goin to leave the wiring the way it was but the guy who had it before me had 3 different fuse boxes and bare wires all over the place... and because of that Ive had a couple of fires in my dash.. and as far as the floor pans go I probly will just patch the smaller ones with filler and weld the larger ones.... And yes thats my suspension racing seat... If anyone can see anything else I need to do let me know..
cwick1989
cwick1989
Posted: Mon Apr 12, 2010 05:11 AM
How hard is replacing a wiring harness and what all do the new harness come with... such as fuse boxes fuses etc.
Baja_Blue
Baja_Blue
Posted: Mon Apr 12, 2010 08:14 AM
depends on where you buy them from, some kits come with everything from fuses to switches to fuse box etc.
Once you get a general idea of the wiring on a bug it's the simplest wiring you will ever find compared to any other car out there.
I know Bugz does complete rewire for a good price if your looking for someone else to do it
Matthew 5:14-16
4 Admin_AzBaja 5055 Baja Bugs on Wiki need...
1567 mufasavnvmc 838130 what did you do to you...
 Tue Aug 15, 2017 03:29 AM
285 MusicManiac 205681 Re: Baja sightings
Off-road event
1 wideopenmotorsports 117 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 3130 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
