Visitors: 202
Total: 202
03: Event Calendar
156: Pictures
158: Baja Forums
160: Event Calendar
183: Baja Forums
186: Baja Forums
187: Baja Forums
190: AMAZON.com
191: Event Calendar
194: Baja Forums
196: Baja Forums
197: Baja Forums
198: Baja Forums
200: Home
202: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- negative camber in the rear
ChuckD
ChuckD
Post Post subject: negative camber in the rear
Posted: Sat Apr 03, 2010 08:42 AM
Gentlemen,
I have a 69 baja (irs of course), but have a preposterous amount of negative camber ( top of wheel in, bottom out) in the driver side rear. The local expert proposed it was a bent "stub axle." After taking it apart, it looked pretty straight to me.
1. Is there a measurement I could do to make sure the stub axle is straight and true?
2. Could it be something else?
Thanks for any and all help.
CHUCKD
Post Post subject: Re: negative camber in the rear
Posted: Sat Apr 03, 2010 02:26 PM
Picture?? It should be a bent trailing arm.
Posted: Sat Apr 03, 2010 06:31 PM
i'm with Perri on this one, sounds like it could be a trailing arm.
ChuckD
ChuckD
Posted: Sat Apr 03, 2010 07:53 PM
would you like me to put the stub axle and the tire back on for the pic?
is there a measurement i can make to see if its the trailing arm?
Posted: Sat Apr 03, 2010 07:56 PM
It is not the rim or stub axle as the tire would spin in an eliptical pattern.
Is your trail arm becoming unbolted?
ChuckD
ChuckD
Posted: Sat Apr 03, 2010 08:41 PM
negative. i tightened both sides before i left for mexico, and the cotter pin is still in.
Posted: Sat Apr 03, 2010 09:03 PM
Trail arm bolts? 17 mm allen and the three holding it to the arm?
vwbill
vwbill
Posted: Sun Apr 04, 2010 01:09 AM
Does your 69 have double spring plates or single?
ChuckD
ChuckD
Posted: Sun Apr 04, 2010 11:17 AM
Yes, a 17 mm allen was tightened and torqued and cotter pinned.
Not sure what the difference between single and double sring plates are though.
vwbill
vwbill
Posted: Sun Apr 04, 2010 12:26 PM
Some cars had two spring plates per side that the trailing arm mounts too. I did a IRS conversion to a swingaxle and had the same problem you have. I had double spring pates on each side. Can't find any proof, but there are two trailing arm designs. Only visual difference is bolt mounting pattern. Both have four bolts, One has three corners of square and a center and the other has a square. Mix the two and only three corner bolts line up. Does that make sense?
William
ChuckD
ChuckD
Posted: Sun Apr 04, 2010 08:25 PM
I think i know what you're talking about Will. I do have 2 spring plates per side and a "square pattern" although couldnt the "3 corners and a center pattern be underneath the top piece with the "square pattern?" The square covering the center pattern?
Anybody know how to tell it you have a bent trailing arm?
-but if it was bent, wouldnt that mess up the shock and mount (a visible difference in angle of the shock?) some rubbing or vibration?
thanks will
Posted: Sun Apr 04, 2010 09:20 PM
Your making it way more complicated than it is. You either have a bent trailing arm or a bent torsion housing. It bends where the spring plate extension is welded to the diagonal tube. Thats why the good reinforcement kit triangulates the stock arm with chromoly tubing.
ChuckD
ChuckD
Posted: Sun Apr 04, 2010 09:40 PM
I thought it was getting a bit crazy. Measurement time.
Thanks perrib
Posted: Sun Apr 04, 2010 09:41 PM
X2
vwbill
vwbill
Posted: Mon Apr 05, 2010 01:30 AM
Maybe I misunderstand your post. Did you notice a camber change after a ride or after installing a new part? I was assuming you put on a new part.
No new posts VW Volkswagen & Baja Bug General Discussion Max angle for rear axles 5 Wattsd 3419 Re: Max angle for rear...
 Fri Jan 29, 2016 05:03 AM
Wattsd View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Rear Rim Backspacing 1 LittleBaja 2113 Rear Rim Backspacing
 Fri Nov 06, 2015 04:13 AM
JWHracing View latest post
what do you use
4 bdrdunes 2704 Baja bug rear led ligh...
 Thu Dec 18, 2014 03:55 AM
No new posts Projects and Builds Possible rear seat?? 4 TattooedIrish 4013 Possible rear seat??
 Thu Aug 30, 2012 08:55 AM
Rigger View latest post
irs,swingaxle
3 desertbaja 3086 Re: 1968 vw beetle rea...
 Tue Aug 28, 2012 04:37 PM
