Visitors: 93
Total: 93
07: Event Calendar
24: Event Calendar
54: Event Calendar
59: Event Calendar
78: Event Calendar
89: Home
1 2 3 ... 36 37 38 ... 103 104 105
kozilla
kozilla
Posted: Wed Mar 17, 2010 07:02 PM
oil change
changed filter
new plugs
valve lash
rewired old crusty wires
installed oil pressure and volt gauge
adjusted lights
blew oil all over my driveway (idiot that had it before me broke the valve cover by overtightening the bolts) LOL
Pissed off a few neighbors at night with the stinger singing...
Billy
Billy
Posted: Thu Mar 18, 2010 05:12 AM
Took front fenders and 'rough mounted' them on the back and measured and designed how I will make them into rear fenders. Should be able to start cutting and painting Saturday or Sunday. Have a dizzy coming in the mail and when it gets here I will be able to replace the point plate in mine and see if the bug comes back to life.
In tuning it a few months ago (before winter) I stripped the point plate in the distributor during a tune up so hopefully after retuning, all will be well Smile
Rickman
Rickman
Posted: Thu Mar 18, 2010 01:37 PM
Cleaned up my stripped rims and sprayed the first coat of paint. Will spray on the 2nd and 3rd coats this afternoon.
TrailRail2110
TrailRail2110
Posted: Thu Mar 18, 2010 04:35 PM
what kind of paint are you using for your rims? i am going to be repainting mine soon'ish. i originally used a rustoleum hammered spray paint, to help hide the flaws.
DutchBug
DutchBug
Posted: Thu Mar 18, 2010 06:24 PM
Hammeright is good stuff, do you have that in the US?
They have a version without the hammered look now too.
I believe in spraycans as well.
Rickman
Rickman
Posted: Thu Mar 18, 2010 10:03 PM
I'm using a Rustoleum paint. Brushed aluminum look. I picked it up at IC Delux Paints.
rgc3102
rgc3102
Posted: Fri Mar 19, 2010 02:50 AM
removed the torsion bars....now I'm waiting on my coil over conversion kit.
RGC
little_penny
little_penny
Posted: Fri Mar 19, 2010 05:06 AM
Replaced broken clutch cable Sad
www.BajaDreamRacing.com
pelg
pelg
Posted: Fri Mar 19, 2010 05:36 AM
put in a carpet pad kit from wolfsburg west after having put FatMat in the back, put back the carpet and put my backseat and seatbelts back in. man what a difference
Posted: Sat Mar 20, 2010 12:58 AM
Washed the winter sand and salt off it today. Time to get it muddy. Cool Cool
Brettucks
Brettucks
Posted: Sat Mar 20, 2010 03:04 AM
this week bled all brakes, created a new seal for master cylinder, checked tranny oil, adjusted clutch, installed new door handles, got tubes for front tires, and did toe in alignment...
Rickman
Rickman
Posted: Sat Mar 20, 2010 11:49 PM
The rims are painted. I will be installing these on the rail. Now if my Son would bring back my truck so I can take them down and get the tires mounted. Nanco 7.00 X 15's for the fronts. Probably the Definity Dakota M/T's 31 X 10.50 15's on the rear. The front rims are 5inches wide and the rears are 8inches wide.
There's a ding on one of the rear rims. I hammered a little with a sledge. Looks like it should still hold air. You can see in the pic.
Good Ol' Rust-O-Leum. 5 light coats on the front and 3 coats on the back.
Posted: Sun Mar 21, 2010 01:22 AM
Mounted up my radio (Christmas gift) finally. Rolling Eyes Used the "Glass Action" fiberglass under ash tray radio/guage holder. Works and looks great! Cool
Now I need to carpet under the dash and kick panels so I can mount up the fiberglass speaker mounts on the kick panels and get my front speakers in. Wink
Posted: Sun Mar 21, 2010 07:25 AM
started putting my new turbo on today. got everything done except hooking the oil to the turbo up and adding the muffler to the set up
Posted: Mon Mar 22, 2010 12:18 AM
If you need a hand gimmie a call Cool
4 Admin_AzBaja 5559 Baja Bugs on Wiki need...
285 MusicManiac 215368 Re: Baja sightings
0 Northmountainauto 16 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1056 Baja hiding in Chandle...
Off-road event
1 wideopenmotorsports 831 Re: Baja run in March
 Mon Jan 08, 2018 06:09 PM
