Visitors: 129
Total: 129
17: Home
19: Event Calendar
53: Pictures
55: Home
71: Pictures
1 2 3 ... 35 36 37 ... 103 104 105
Posted: Tue Mar 09, 2010 03:32 AM
I got it new rear tires.
TrailRail2110
TrailRail2110
Posted: Tue Mar 09, 2010 04:55 PM
What kind, any pics?
Posted: Wed Mar 10, 2010 12:35 AM
Two new BFG All Terrains 33x12.50x15
They came mounted on 15x8 wide five Centerlines.
I also picked up a brand new 33x10.50 BFG Mud Terrain on a Chevy rim and a used one for the spare. This will be the next size rear tire on the rail.
TrailRail2110
TrailRail2110
Posted: Wed Mar 10, 2010 04:47 PM
wow thats alot of tire. i thought my 31x10.5 was a stretch, they look really sweet!
DutchBug
DutchBug
Posted: Wed Mar 10, 2010 04:53 PM
I've been sanding sanding sanding.
Grinded some metal away from the rear.
And removed the clamps that hold the hood rubbers.
Also been figuring out what to do with the dash.
I'm thinking about grinding a stripe of the bottom and putting it on another angle. Should be nice.
Baja_Blue
Baja_Blue
Posted: Sat Mar 13, 2010 08:43 AM
tinted my windows and got some new Pro Comp Rims...in Photoshop hahaha
Matthew 5:14-16
Posted: Tue Mar 16, 2010 02:03 AM
nice photoshoppin blue Cool looks good Very Happy
Posted: Tue Mar 16, 2010 04:56 AM
I started pileing parts in all 3 to get them moved to the new house.
Posted: Tue Mar 16, 2010 06:09 AM
Drove mine to Tim's in AJ (Marvin Shaw shocks) and had them service all four shocks with nitrogen. Drives like a whole different car!
Posted: Tue Mar 16, 2010 02:28 PM
Cool
Tim does good work, and rumor has it Tim is rockin a new 14" wider Bugzyla Beam on his rail, and soon th be 3" lift spindles too.
Baja_Blue
Baja_Blue
Posted: Tue Mar 16, 2010 03:59 PM
BugZyla.com wrote:
8)
14" wider?? Shocked Shocked
Matthew 5:14-16
DutchBug
DutchBug
Posted: Tue Mar 16, 2010 05:13 PM
Sanding and refitting the hood. As you can see in the picture there is a large gap in the middle and it is stuck on the sites. I grinded a ribbon of but the 'height' curve is not okay either so I'm still figuring out how to make a better fit. Perhaps by putting it under tension with a spanner and then glue some fiberglass to keep it in place. The hoods shape just isn't right Sad
Rickman
Rickman
Posted: Tue Mar 16, 2010 05:48 PM
Picked up my rims for the rail. Had them stripped all the way to bare metal. Now to get em' painted and the tires mounted.
Baja_Blue
Baja_Blue
Posted: Wed Mar 17, 2010 06:53 AM
Started taking some of the carpet out for the cage! Wink
found out the guy who did the carpeting knew what he was doing... I always wondered why my baja is so much quieter than everyone elses I have ridden in...Wellll, the guy did carpet, then under that some insulating soft padding, AND underneath that a styrofoam type insulation material! Cool
hopefully I will be able to get it back in how it was after the cage is in
Matthew 5:14-16
TrailRail2110
TrailRail2110
Posted: Wed Mar 17, 2010 06:22 PM
Corrected valve lash from my last failed attempt, helps when you know what your doing. did a quick clean on the jets for my carb. drained all the old gas out and hopefully corrected the gas leak on the tank spout and fuel pump. reseated the super trapp discs a little lighter, i over tightened the first time.
5 Admin_AzBaja 6746 Baja Bugs on Wiki need...
285 MusicManiac 240977 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1263 Re: Had to go play in ...
0 Northmountainauto 1511 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 4085 Baja hiding in Chandle...
