Visitors: 129
Total: 129
43: Pictures
53: Pictures
62: Home
68: Event Calendar
114: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- fuel tank options?
fuel tank options?
Post Post subject: fuel tank options?
Posted: Thu Oct 19, 2006 07:09 AM
Hello, I am extremely new to all things Baja Bug. I just bought a 66 and am trying to figure out some basics before planning it all out.
I see some people w/ a 1 pc front end use the round fuel tanks w/o a lot of bracing from the footwell to the beam and other cars w/x-braces taking up the entire front. These are the only options? Fuel cell in back seat area and x-brace or round tank and less braces? Strong enough?
Thank you for your time and opinions.
Post Post subject: Re: fuel tank options?
Posted: Thu Oct 19, 2006 07:16 AM
let your imagination fly Very Happy Wink
72BajaBen
72BajaBen
Posted: Thu Oct 19, 2006 07:57 AM
remember if you have a round fuel tank like me you will more than likely, i havent fuond one yet, that has a fuel guage sender.
Posted: Thu Oct 19, 2006 08:00 AM
the floor pan of the VW is like a big go kart, the body is not a major part of the suport structure. But once you get to the point were you will real abuse the car you need to start adding cross bracing cages etc. The floor pan will not hold up to the kind of abuse that a race buggie will see but it will do ok for a weekender.
Posted: Thu Oct 19, 2006 05:59 PM
Thank you for your input. Do most of you go with the pre-made beam to body supports ie..chirco's and round tanks? Or with custom bracing?
Posted: Thu Oct 19, 2006 07:00 PM
what ever is affordable
72BajaBen
72BajaBen
Posted: Fri Oct 20, 2006 03:38 AM
i think that it all depends on what you want to do with your car. if you want to do alot of offroading then do the bracing, but if it is a daily driver and you just take it offroad for fun on the weekends, then i would just do what is cheaper.
bajasam96
bajasam96
Posted: Fri Oct 20, 2006 05:33 AM
As long as the terain isnt covered with many big boulders you'll probably have no problems without beam braces. But it never hurts to be safe.
Posted: Fri Oct 20, 2006 05:35 PM
Thank you for your responses!
69bapbaja
69bapbaja
Posted: Mon Oct 23, 2006 07:22 AM
Here's a thought take a look before you cut. you can still have a one piece front end with out cuttin the tank seat off. Then use a tank from a 67 and earlier and still have a sending unit.
OWNER OF
Two Kats Tats
5030 W. Peoria
Glendale, AZ
85302
(623) 934- 9197
Posted: Mon Oct 23, 2006 04:40 PM
You can also do what I did. I used the round aluminum tank, and cut a hole in the top, and drilled & tapped the holes and put a sending unit in it. Just use the rubber gasket to mark the holes.
No new posts VW Volkswagen & Baja Bug General Discussion VW baja bug Exhaust options? 4 71VeeDub 6898 Re: VW baja bug Exhaus...
 Sun Nov 27, 2011 04:23 AM
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 1716 rack & pinion w/stock ...
 Wed Nov 09, 2011 07:44 AM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Help Needed --> Gas Tank Safety!! 2 jk97 2300 Help Needed --> Gas Ta...
 Wed Jul 13, 2011 06:23 AM
Replacement Possible or Not
3 jemizasi 3417 1966 VW Beetle Fuel Se...
 Fri Apr 29, 2011 05:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion Fuel pump failure 2 chickenpants 1765 Re: Fuel pump failure
 Mon Nov 02, 2009 07:57 PM
chickenpants View latest post
