Visitors: 127
Total: 127
36: Home
77: Home
78: Home
1 2 3 ... 34 35 36 ... 103 104 105
62ragtop
62ragtop
Posted: Thu Feb 18, 2010 12:04 AM
perrib wrote:
I took mine to the spa and we got a mud pack treatment.
So I see that wearing a helmet is sometimes a good thing.
conejo
conejo
Posted: Thu Feb 18, 2010 06:30 AM
I disassembled and cleaned the cv's. Also bought a bunch of parts I'll need to for putting in the engine and transmission this Saturday.
Rich C.
Posted: Fri Feb 19, 2010 03:51 PM
I adjusted the rails front brakes.
TrailRail2110
TrailRail2110
Posted: Fri Feb 19, 2010 04:45 PM
Removed my Power pully and put the stock size back on to get the proper cooling back, also put a new sand pully seal in.
Got my parts delivered yesterday with my Kep1 and kush lock, oil breather, super trap exaust and other misc. so i will be busy for a couple weeks getting this all installed and getting the rail ready for spring.
conejo
conejo
Posted: Sat Feb 20, 2010 07:09 AM
I removed the oil cooler from under the rear package tray. That's where the PO had it mounted, but I don't think it was a very good spot. I need to get a new oil cooler now.
Also attached the urethane transaxle mounts to the transaxle.
Rickman
Rickman
Posted: Sat Feb 20, 2010 05:27 PM
Repaired some wiring for the driving lights. Man, the PO had a "bunch" of splices inside the wiring covers! Might need to do a re-wiring job in the future to remove all of those splices. Different gauge wiring, poor crimps, etc., etc.
Rickman
Rickman
Posted: Sat Feb 20, 2010 05:28 PM
Oh, and the big brown truck dropped off two new 7.00 X 15 Nanco tires. Just waiting to get the front rims back from media blasting so I can rattle can them and then find someone to mount them. Now to find some good 31 X 10.50 15 tires. Saw some nice ones at Pimp Boys yesterday.
conejo
conejo
Posted: Sun Feb 21, 2010 04:18 AM
I got the transaxle mounted today. Can't believe it took so long, but I made a couple rookie mistakes. Used urethane mounts & a padded strap kit.
I screwed up when I put in the transaxle, and tightened the front mount down all the way. It wasn't lined up properly, so I chased my tail around the rest of the day trying to 'fix' that. Wasn't until later when I loosened the front mount that it set in there straight. Oh, well it's all good now & my Dad had a few chuckles watching me.
Tomorrow I need to get a shorter bolt for the front strap that won't hit the transaxle case. Hooray for Ace Hardware!
Might even get the engine mounted up tomorrow.
Rich C.
Posted: Sun Feb 21, 2010 12:03 PM
you Dirty man you...
rgc3102
rgc3102
Posted: Mon Feb 22, 2010 03:58 AM
Installed my new fuel filler neck behind the left quarter window. I hope I added the picture correctly.
RGC
conejo
conejo
Posted: Mon Feb 22, 2010 05:23 AM
I finished getting the transaxle straps bolted down, got the cv's greased and installed.
Took out the passenger seat so I could get in back to hook up the shifter coupling, but the grub screw is missing. I'll have to go scrounge one up tomorrow. While I was in the back I looked at the battery & electrical connections. It's a disaster. I'm seriously thinking of yanking all the existing wiring & starting clean.
Baja_Blue
Baja_Blue
Posted: Sun Feb 28, 2010 10:10 AM
Changed the oil in the trans today and replaced the axle boot's since one was cracked. pain in the butt to do
the oil had probably never been changed...it came out in chunks lol
hey it shifts smooooth now Cool
Matthew 5:14-16
Baja_Blue
Baja_Blue
Posted: Tue Mar 02, 2010 09:04 AM
Welded a piece of tubing over my tie rod to strengthen it and put new tie rod ends on Cool
Matthew 5:14-16
TrailRail2110
TrailRail2110
Posted: Wed Mar 03, 2010 04:56 PM
Installed my freshly machined lightened flywheel, new rear main seal, KEP 1 and kush lock, new oil pressure sender, installed breather box on frame, drilled out valve covers and put breathers on, replaced gear and motor oil, new Fram oil filter, cleaned and oiled my air filter with a K&n Kit so now its a red color, resealed axle boots with rtv, got my new german throw out berring installed with HD clips and used a some RTV to help keep them in place.
busy busy, want to get my engine back in and fired up by the weekend maybe take it for a test drive with the new clutch, see how she does in the snow!!!
Baja_Blue wrote:
Those rods look great that should work awesome for you, i have bent a few tie rods my self. I have a Machinest buddy who is in to rails and he made me a set of 1" 5051 aluminum tie rods.
BTW there is a Lucky Penny Pick it up!
Baja_Blue
Baja_Blue
Posted: Wed Mar 03, 2010 10:05 PM
[quote="TrailRail2110"]
Thanks! yeah I just bend a tie rod out on the So Cal Baja's run...see that ditch in the backround? Evil or Very Mad
The picture makes it look like the short tie rod was bent but I just had the wheels turned so I could pound out the tie rod ends
and cool! those 5051 rods should hold up!
Matthew 5:14-16
5 Admin_AzBaja 7116 Baja Bugs on Wiki need...
285 MusicManiac 244407 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1532 Re: Had to go play in ...
0 Northmountainauto 1695 Shop Baja
