Visitors: 104
Total: 104
03: Pictures
08: Pictures
42: Pictures
51: Home
62: Home
94: Event Calendar
101: Event Calendar
FABINC 5-1600 Build
1 2 3 4 5 6 7 8 9
Posted: Sat Aug 29, 2009 06:41 AM
A month ago I came into possession of a 5-1600 build. The foundation was created in Gilbert by James at FABINC.
[img][/img][img][/img][img][/img]
I will try to update monthly.[u]
Posted: Tue Mar 02, 2010 05:01 AM
Took some time to clean up the firewall and rebuild the rear suspension and brakes.
Posted: Tue Mar 02, 2010 11:52 PM
Looks nice.
Baja_Blue
Baja_Blue
Posted: Wed Mar 03, 2010 07:31 AM
DONT wrote:
Looks nice.
x2 super clean
btw are those type 181 Drums per class 5/1600 rules?
Matthew 5:14-16
Posted: Thu Mar 04, 2010 02:16 AM
No they are not Thing drums. However, new SCORE rules allow disk brakes all the way around.
I am looking for a set of Thing drums/baking plates though. Can't afford disk brakes, but Thing brakes will work for what I want to do.
Do you have an inside line on some?
Baja_Blue
Baja_Blue
Posted: Thu Mar 04, 2010 07:29 AM
Okay, they look like them for some reason...I didn't realize those are wheel adapters on there
yeah Thing brakes are definately better I have a buddy who uses them
Don't have an inside line on them though
Matthew 5:14-16
Posted: Sun Jun 06, 2010 05:39 AM
A few more photos.
jone$yyy
jone$yyy
Posted: Sun Jun 06, 2010 08:08 AM
the baja has a lot alot o lot of work into it man glad to see someone finally do something with it instead of just being a shell good luck man
cant wait to see it done
james will be pleased to see this also....
good luck brothea
Posted: Tue Jun 08, 2010 03:57 AM
Did a little work on the hood. I think the results are pretty good.
Front suspension is next.
Posted: Sun Jul 04, 2010 09:34 PM
Some recent photos of front end.
View entire album at: photobucket.com/wideop...rts_5-1600
Next up: Brake and clutch pedal assembly.
jone$yyy
jone$yyy
Posted: Tue Jul 06, 2010 02:22 AM
very nice man
finally some one is doing something with it
very nice keep up the good work
bajabuggin
bajabuggin
Posted: Wed Aug 04, 2010 12:14 AM
this car and Mine are the only ones built by James, i have pics posted of mine throughout its progress. still alot of work to do but we got done with all the framing and suspension about a month ago. im glad someone is doing somthing with it as well i know its had a few owners now.
Posted: Wed Aug 04, 2010 04:27 AM
I had no idea the history of this car. I hope to do it justice. I have several ideas that will come into play as the car gets closer to completion. I cam currently working on the dash and gauges this weekend. Hopefully I will have a few more pics of the pedal assembly and dash.
Thanks for all the positive remarks from the group.
Posted: Tue Aug 24, 2010 02:18 AM
Working on the brake lines, pedal assembly and fuel filler neck.
[img][/img][img][/img][img][/img][img][/img][img][/img][img][/img][img][/img][img][/img]
Posted: Sun Oct 03, 2010 07:57 PM
Took some time this weekend to start the wiring of the car. New dash was the first requirement.
Time to fill the empty space[i]
Use the new dash and some cardboard for a template.[/i]
Create template and trace onto the white protective film that comes on the dash.
[i]
Used a hole saw to cut what shapes I needed and a dremel tool to touch it up. VDO only gives a few mm for error. Measure twice, cut once.[/i]
Finished dash with all new gauges and SunPro Monster tach.
[b]
[i]
New dash fits great. Take a lot of time to measure and remeasure. I cut 4 templates before I transferred it to the actual dash.[i][u]
1 2 3 4 5 6 7 8 9
26 1963BAJA 7328 The Socal Honda Build
 Fri Jun 23, 2017 12:15 AM
1963BAJA View latest post
Cheapskate special
26 Azdrtdog 11387 New father/son budget ...
 Fri Jun 16, 2017 10:26 PM
No new posts Projects and Builds New Class 11 Build - PepeBlanco 4 pepeazul 5216 New Class 11 Build - P...
101 SuburbanLegend 134482 Carbon Footprint...aka...
 Thu Oct 08, 2015 08:28 PM
No new posts VW Volkswagen & Baja Bug General Discussion 5-1600 vs Class 11 Version 3 2 wideopenmotorsports 3368 5-1600 vs Class 11 Ver...
 Thu Oct 08, 2015 08:12 PM
