Visitors: 127
Total: 127
28: My Account
32: Event Calendar
41: Event Calendar
42: Event Calendar
69: My Account
75: Event Calendar
89: Pictures
94: Event Calendar
109: Pictures
115: My Account
122: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- bearing in side bj beam
1969Type1BAJA
1969Type1BAJA
Post Post subject: bearing in side bj beam
Posted: Sun Feb 14, 2010 01:12 AM
how do you get the most inner bearings out of the beam thanks
Post Post subject: Re: bearing in side bj beam
Posted: Sun Feb 14, 2010 05:17 AM
This can only be revealed if you know the secret AZBAJA handshake. Smile
1969Type1BAJA
1969Type1BAJA
Posted: Sun Feb 14, 2010 06:00 AM
No one uses thier left first then thier left hand for the secret Azbaja hand shake.
chickenpants
chickenpants
Posted: Tue Feb 16, 2010 02:58 AM
Shoot, I wanted to know too.
Stephen\r\nChandler, Az
Posted: Tue Feb 16, 2010 03:13 AM
Measure the EXACT inside dimension of your beam without the bearings. Get a big fat washer at the hardware store that's slightly larger than that. Also get a piece of all-thread, three nuts, and some washers that will fit inside the big washer. Grind two flat spots off of opposing sides of the washers so it has two flat edges and two round edges. Grind the round edges to match the ID of the beam exactly. If you did it right, you'll be able to barely fit the washer in the end of the torsion tube, and you'll have two gaps, one on either side, as you look at it inside. Put the all-thread inside of the modified washer with a nut and washer on each side of it loosely. As you push the large washer down into the torsion tube, it will tip on its axis and clear the bearing. Once it has cleared, you can pull it back and it will fit nice and snug on the back side of the bearing. Put a scrap piece of steel (or wood, whatever...) with a hole in it up against the face of the torsion tube with the all-thread poking through it. Now you can use that third nut and washer to tighten up on the wood block, or steel block, which will cause the large washer inside to pull the bearing out like a puller. Likewise, when you get it to the end of the torsion tube, if you can't get it out, you can slide a metal pipe down the all thread and bang on it like pulling dents with a slide hammer.
Did that make any sense, or do I need to draw a picture?
chickenpants
chickenpants
Posted: Tue Feb 16, 2010 07:19 PM
Thanks, nice writeup. Made it clear for me.
cperry2704
cperry2704
Posted: Thu Feb 18, 2010 04:21 AM
good luck...its a pain getting them out
1969Type1BAJA
1969Type1BAJA
Posted: Sat Feb 20, 2010 09:16 PM
after some fighting and wanting to rip out my hair i got all four of them out tanks foe the tip now i just need to get the torsion bars back in Mad
cperry2704
cperry2704
Posted: Sat Feb 20, 2010 09:30 PM
i installed adjusters in mine, let me tell ya...getting those torsions back in! talk about pulling your hair out!
1969Type1BAJA
1969Type1BAJA
Posted: Sat Feb 20, 2010 09:57 PM
i want to just go with the all thread and coil over but thats lots more work to any tips on how you did yours
cperry2704
cperry2704
Posted: Tue Feb 23, 2010 12:04 AM
get them all together and some tape to hold them inplace and try and get them through
1969Type1BAJA
1969Type1BAJA
Posted: Tue Feb 23, 2010 06:56 AM
i was thanking a hose clamp close to one end to keep it tight and push it in one way all the over and then back to get the hose clamp off
25 Kreed 26241 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Bent beam 1 cperry2704 1373 Bent beam
 Tue May 30, 2017 03:38 AM
JWHracing View latest post
No new posts Events and Get Togethers World Wide AzBaja WEST SIDE MEETING
[ Go to pageGo to page: 1 ... 10, 11, 12 ]
172 wideopenmotorsports 73514 AzBaja WEST SIDE MEETI...
 Thu Aug 14, 2014 08:27 AM
No new posts Club AzBaja (Arizona Chapter) West Side Trail Run?
35 Dirtjunkie 17547 West Side Trail Run?
 Thu Oct 03, 2013 02:13 AM
No new posts Events and Get Togethers World Wide West Side Caravan to Bug O Rama? 9 Dirtjunkie 5034 West Side Caravan to B...
 Sat Mar 24, 2012 05:27 AM
biblethumpncop View latest post
