Visitors: 99
Total: 99
90: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Should i buy...
Should i buy...
AndrewSm09
AndrewSm09
Post Post subject: Should i buy...
Posted: Wed Feb 10, 2010 07:48 AM
Ok so i found a project baja i wanna buy, my first project ever. And i want you guys opinion.
Heres the Info.
$600
1975 Bug
Motors good but needs to be put back in
Was fuel injected, but now is carbed, said theres wiring stuff to be done there, how extensive is that?
Tranny, axles, CV joints, suspension, steering all in and work
Also needs seats
Need to buy a fuel cell and low pressure fuel pump for it, how technical is installing those?
Like i said, my first project, something to start learning on, only 19 by the way.
Opinions or help info?
baja62
baja62
Post Post subject: Re: Should i buy...
Posted: Thu Feb 11, 2010 12:20 AM
YOU SHOULD BUY MY BUG LOOK IN THE FOR SALE ADDS UNDER LONGTRAVEL. Laughing
longtravel
AndrewSm09
AndrewSm09
Posted: Thu Feb 11, 2010 02:08 AM
Man would i love to buy it, but do i not only not have 2k, I also would have to find a way to get it, and get a motor. Now if it was in running condition, i would be more than willing to trade you for my 1990 Cadillac daily driver.
Baja_Blue
Baja_Blue
Posted: Thu Feb 11, 2010 07:36 AM
Heres the Info.
$600
1975 Bug
Also needs seats
Certainly is a project. But hey, 600 is pretty good. post some pictures.
I assume it is a VW motor?
-No idea what has been done or needs to be done with fuel injection.
-That is good that all the suspension and steering check out.
-Seats are easy. look on the samba, or just Chirco
-Fuel cell can be semi-hard depending on how you want to mount it. technicality of installing fuel lines, fuel pump, etc is really easy.
if you are looking for a project, go ahead. But it sounds like it will take quite a bit of work to get running
Matthew 5:14-16
AndrewSm09
AndrewSm09
Posted: Fri Feb 12, 2010 01:36 AM
He sold it.
Found another, runs good, 800 dollars. Brakes need some work, steering to adjusted. Waiting for a reply
Baja_Blue
Baja_Blue
Posted: Fri Feb 12, 2010 07:05 AM
cool man. Good luck
Matthew 5:14-16
