Visitors: 113
Total: 113
05: Event Calendar
17: Pictures
40: Event Calendar
41: Event Calendar
52: Event Calendar
53: Event Calendar
67: Drivers
68: My Account
73: My Account
76: Event Calendar
90: Event Calendar
99: Event Calendar
108: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- oil cooler setup..
oil cooler setup..
Brettucks
Brettucks
Post Post subject: oil cooler setup..
Posted: Sun Feb 07, 2010 11:19 PM
I currently have the kit that has filter mounted to oil pump cover (filter sits horizonatlly to the left)...
Could I just get one of those spin-on sandwhich adapters to run the oil lines to/from the cooler?
-Brett
Post Post subject: Re: oil cooler setup..
Posted: Mon Feb 08, 2010 04:29 AM
You could. There used to be a kit for the T-4 that worked that way.
Posted: Mon Feb 08, 2010 05:37 AM
I'm a big fan of those filter/pump combos, and have been running them for years. I thought of that exact same thng once, and actually even bought the adapter. After looking very closely at it, I dcided against it. The holes to let the oil in and out were quite small and looked very restrictive. It made me real nervous, so I crawfished on the whole idea and went a different route.
I was reading about how they full-flow type 3's the other day, and I might try that on an engine some day. It was really cool. On a T3, you don't have any room to pump the oil out at the filter and then back behind the engine because the fan shroud interferes with it. They drill a hole in the side of the case by where the oil pressure sender is on a T1 and put a plug in between them to force the oil out an back in. I wouldn't try that with an assembled engine, though.
Baja_Blue
Baja_Blue
Posted: Mon Feb 08, 2010 05:43 AM
hey speaking of oil pressure sender hole...Mine has a a hose going all the way to the front of the car to the oil pressure gauge!
kinda scares me I have oil running all the way to the front...
anyone else have this?
sorry for the thread jack...
Matthew 5:14-16
Posted: Mon Feb 08, 2010 06:47 AM
Scares me to and it is not even my engine. It does not take long to drain a running engine of oil when the plastic hose rubs through on a sharp piece of metal.
Baja_Blue
Baja_Blue
Posted: Mon Feb 08, 2010 09:00 AM
yeah I put 300psi rated hose to the metal line it goes to. I'm thinking I convert it to electronic pretty soon here
anyone ever heard of even having this? every VW mechanic I've gone to has said the same thing..."what the hell is that for?" lol
Matthew 5:14-16
Brettucks
Brettucks
Posted: Tue Feb 09, 2010 03:57 AM
Sounds like the ole 'mechanical' guages... I had a ford truck with one that did get cut ... didnt run out of oil but foot was showered with hot oil for about 5 seconds till I turned it off and coasted anyway..
I think this is not full flow but doing it anyway as it is much easier for now.. plus if head temperature guages get hooked up I will have some warning, and if oil cooler gets harmed you can just spin off filter, spinoff adapter and reassemble... filter being inside cage will give some insurance..
-Brett
No new posts VW Volkswagen & Baja Bug General Discussion Rack and Pinion setup on a Baja bug 3 DFWbaja 4206 Rack and Pinion setup ...
 Fri Jan 30, 2015 02:44 PM
No new posts VW Volkswagen & Baja Bug General Discussion Baja roof height with 3x3 setup 3 ghettodish 3417 Baja roof height with ...
 Wed May 18, 2011 05:17 PM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion shock setup 5 thext94 4832 Re: shock setup
 Wed Apr 14, 2010 02:16 PM
No new posts VW Volkswagen & Baja Bug General Discussion Carb and intake setup? 11 Torg37 7291 Carb and intake setup?
 Fri Feb 05, 2010 04:26 AM
57baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Best carb setup for regular street use and some off road 1 trailblazr81 2477 Re: Best carb setup fo...
 Tue Jan 05, 2010 07:52 AM
