Latest: BlackIrish05009
Overall: 3574
Visitors: 122
Total: 122
21: Pictures
80: Pictures
89: Event Calendar
98: Event Calendar
109: Pictures
111: Event Calendar
Baja Forums -:- AzBaja.com Members -:- New Members -:- TrailRail2110-My New Obsession**pics**
TrailRail2110
TrailRail2110
Post Post subject: TrailRail2110-My New Obsession**pics**
Posted: Wed Feb 03, 2010 09:09 PM
I have been reading your site for months now and have to say its one of the best i have come across, That being said.
I bought this rail in the Fall of 08' coming off an 86' Honda XR250. I was used to the 2 wheel toys but knew nothing of VW other than i liked the idea of these rail/buggies. I got it running drove it a couple times then tore it down, during the winter spring, to the frame and basicly built everything new and tried to make it bigger/better. I like to drive it like a dirtbike but with a little more protection for me and a friend.
Hope you dont mind that i listed most of my moddifications.
Last updated: 6/21/14
Buggy description:
Street Legal buggy
Engine:
2175cc Stroked Motor build by Greens Vw Racing, Worked Big bore Head and Manifold. Webber 44 w/jet doctor, 75 amp alternator, Bosch Blue Coil, Chrome Tin, 1.5 stinger exhaust w/ Magnaflow Muffler, lightened/balanced 8 dowel Flywheel, Stage 1 Kennedy and a Daikin Disc, off road oil breather, Mesa oil cooler, Full Flow filter, Brad Penn 20w-50 race oil.
Transmission:
B&D custom performance type 1 swing w/ IRS trans case, Super Diff, Erco HD side cover 4.12 R&P, CNC Hydraulic Clutch w/ Saco Slave mount, Sway-Away HD axles, HD steel shift forks, HD cross shaft, german throwout bearring, 80-90 gear oil.
Body:
Berrien short back two seat frame, Diamond plate floor and engine skid plate, Front and rear Baja bumpers, rear disc brakes, kyb gr2 shocks (front), Bilstein 4600 shocks (rear), 1" 6061 solid aluminum tie rods, indexed rear suspension, Four 31x10.5xR15 Dick Cepek off road tires w/Black Steel Racing Wheels, Aluminum 10 gallon gas tank, tree bars, new front BJ beam(old one was rotted).
Interior:
Fiberglass short back seats, 5 point racing seat belts, auto safety glass windshield, Neal Cut Brake, Diamond Plate Control Box
Electrical:
4x LED rear running/brake/turn signals, bright reverse lights, 2x high/low beam headlights, 2x150 watt KC Day lighters driving lights, 3500Lb Gorilla Winch w/custom fairlead mount, Tachometer, Oil Pressure gauge, Oil Temperature Gauge, 132db low tone horn, 400watt Marine Amplifier, 2x 400watt Marine sealed Speakers, New red top optima battery
These last two are the most up to date i have but they are from fall of 09' so i need to get the rail cleaned up and get some new photos
Rickman
Rickman
Post Post subject: My New Obsession
Posted: Wed Feb 03, 2010 10:48 PM
Welcome to the forum!
Nice ride. Looks like it was a good project.
Posted: Wed Feb 03, 2010 11:20 PM
you running a single port?what size is that carb,,i,m running a single.but i have the intakes,for a differant carb than stock,,look,n for ideas,,And,,,nice job on the rail!!!
Posted: Thu Feb 04, 2010 01:53 AM
You seem to be on Rule number 1, We love the pictures here!!!! Thanks!
TrailRail2110
TrailRail2110
Post Post subject: Re: My New Obsession
Posted: Thu Feb 04, 2010 05:56 AM
Its quite unique a 2110 with single ports, but i have a Webber 44 IDF. The Big Bore Heads and Manifold have been worked to get closer to the flow of a duel port. I have tons of low end torque but it cuts out pretty early on the high end. Perfect for my local streets and woods fun.
And thanks, I worked hard on it and i have never done anything like this before. I never knew i could fabricate!
Posted: Sat Feb 20, 2010 02:41 AM
Good Looking Rail.... Shocked Very Happy
Looks like you have jumped in with both feet... Street legal is the only way to go...
My son had a Honda 4x4 and a Banshee, gave them both up for a Type4 powered rail...
There are allot of single port head motors used in Michigan... They make a ton of torque... Great for the sand dunes... I just sold my rails; one was built for the dunes (single port, cam, and big heads) the other one was set up for trails...
I'm running a Baja now... "The Cow Bug".. Mama likes it better..
I'm in Highland & we have a place in St. Helen...
Where do you go riding with your rail Question
Posted: Sat Feb 20, 2010 02:50 AM
Oh Yea I Forgot,
Welcome to the site... If not The Best... Surly One of The Best ...
You will get honest and great advice here too..
Laughing
Posted: Sat Feb 20, 2010 03:55 AM
Welcome to AZBAJA. Nice job on the rail.
TrailRail2110
TrailRail2110
Posted: Sat Feb 20, 2010 07:26 PM
I take my rail all over the state, usually Mio, st helens, Houghton area, Gladwin, Baldwin...i use a trailer so i travel alot. I have been trying to meet other ppl with running buggies i have one and so does my friend dan so we should hit some trails soon. call my cell 810-923-4430
and thanks again the rail is still a work in progress
TrailRail2110
TrailRail2110
Posted: Sat Feb 20, 2010 07:51 PM
I really like your rail, I think i have seen your videos on youtube also! looks like tons of fun.
BugLife
BugLife
Posted: Sat Feb 20, 2010 08:16 PM
I think this is the best VW site and it is because of all of you good people. I'm glad you all love photos "RULE # 1" So Here are some more photos of my Street Baja: And what is in it. 94mm bore 10.05:1 pistons, Ingle w-145 cam staright cut gears, CB 044 heads, all ported &polished, Dual Dell's 45mm, 8or10 Lb flywheel:om/albu[IMG][IMG]http://i746.photobucket.com/albums/xx102/BugLifeOhio/BugLife/017.jpg[/IMG]http://i746.photobucket.com/albums/xx102/BugLifeOhio/BugLife/BugLife001.jpg[/IMG]ms/xx102/BugLifeOhio/BugLife/BugLife004.jpg[/IMG]
TrailRail2110
TrailRail2110
Posted: Tue Feb 23, 2010 08:35 PM
Buglife i like that Baja very sharp!
TrailRail2110
TrailRail2110
Posted: Tue Feb 23, 2010 08:39 PM
I got some update photos of the rail
Just got these tires 31x10.5r15
Posted: Wed Feb 24, 2010 03:07 AM
good looking michigan rail, makes me wanna sell my mini t and look for a rail.
hopefully you'll make it up to the mqt/esky area this summer to go riding.
TrailRail2110
TrailRail2110
Posted: Wed Feb 24, 2010 06:29 PM
Rails are alot of fun but its hard to beat the versitility of an enclosed baja.
No new posts Events and Get Togethers World Wide Hassayampa Pics/Vids 5 wideopenmotorsports 3416 Hassayampa Pics/Vids
 Sun Nov 22, 2015 11:34 PM
No new posts Projects and Builds Pics of my dads build 10 Reggie 6112 Pics of my dads build
 Wed Apr 25, 2012 02:18 AM
Reggie View latest post
No new posts Club AzBaja (Arizona Chapter) WHAT THE HELL!! WHERE ARE THE PICS, 9 jamesr6168 7611 WHAT THE HELL!! WHERE ...
 Fri Dec 24, 2010 03:43 AM
jamesr6168 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion fun weekend (video + pics) 2 thext94 2787 Re: fun weekend (video...
 Tue Nov 02, 2010 06:47 AM
thext94 View latest post
No new posts Events and Get Togethers World Wide April 16th Offroad Adventure - PICS POSTED -
95 jon6.0 32040 Re: April 16th Offroad...
 Tue May 04, 2010 03:49 PM
