Visitors: 123
Total: 123
04: Home
24: Event Calendar
71: Event Calendar
80: Event Calendar
100: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- How to measure the pistons and cylinders?
Torg37
Torg37
Post Post subject: How to measure the pistons and cylinders?
Posted: Mon Feb 01, 2010 03:31 PM
I am wondering how I go about measuring the pistons and cylinders on my current motor so that I can put in a new replacement set of the same size? I know I want Circumference and height correct? but is there a measurement needed for piston pin placement when just replacing the standard piston and cylinders?
thanks
Jerry
Post Post subject: Re: How to measure the pistons and cylinders?
Posted: Mon Feb 01, 2010 04:12 PM
If you cean off the face of one of the pistons the size in mm should be stamped into it, such as 85.48, 90.5, 92.0, 94.0 etc.
Torg37
Torg37
Posted: Tue Feb 02, 2010 01:06 PM
No size was indicated when I cleaned off the piston just an arrow was stamped on the piston?
Posted: Wed Feb 03, 2010 12:40 AM
Then measure the diameter of the bore. To measure the stroke, you measure the distance from the top of the piston from the top of the barrell and BDC and subtract the TDC.
