Visitors: 124
Total: 124
28: Event Calendar
50: Event Calendar
55: Event Calendar
76: Event Calendar
77: Event Calendar
105: Pictures
109: Home
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- building my first baja.....i could use some advice
vindeta
vindeta
Post Post subject: Re: building my first baja.....i could use some advice
Posted: Tue Sep 08, 2009 06:34 PM
danjones333 wrote:
is that house paint that you are painting your pan
haha no its rustomleum clean metal primer and the brown stuff is rusty metal primer.
after this goes the truck bed liner.
lol yea the steering box is out at the moment so the alignment is a little off.
anybody have anything to say about my engine questions?
Posted: Wed Sep 09, 2009 01:06 AM
The pistons are the least of your worries. It is time to split the case and see how much more water damage you have. If I was stuck on the side of the road I would reuse those pistons.
Also KEEP the cage.
vindeta
vindeta
Post Post subject: building my first baja.....i could use some advice
Posted: Wed Sep 09, 2009 06:58 PM
i dont think i have any water damage because the oil on the pistons and in the case looked good when i drained it.
all the junk was inside of the heads themselves.
the engine is in pretty rough condition and it would take a minimum of $600 to get it into running condition, so what im going to try to do is find a good running 1400-1500cc single port and use the dual port heads and manifold from the engine i have now and convert it, ill prolly get some 1600cc cylinders and pistons too.
it doesnt make sense to drop a bunch of money into this engine when i can get a good running one for less.
and i do plan to keep the cage ill need it for the ford zetec or 2.3 swap.
how would you guys suggest i strengthen the frame horns?
i was think i would do like hibbard says and weld the seams, and where the forks meet the chassis gusset it and weld the seems.
what if i took a square steel tube and cut it along two of the corners so it makes a V shape the weld that on the bottom of the horns ??
kinda like this except it would be a little flatter than the V
___
V
Posted: Thu Sep 10, 2009 03:34 PM
___
V
Angle iron is what most use. Much easier than trying to cut square tubing lengthwise.
vindeta
vindeta
Posted: Tue Jan 19, 2010 11:12 PM
sorry i havnt updated in like 5 months but i havnt gotten a whole lot done really.....kinda sad.
between soccer, basketball and life my time has been cut a little shorter.
and for a couple months i kinda didnt feel like working on my baja, im sure you guys know the feeling im taking about, where your like "why did i ever buy this car i should just sell it and buy something else"
but i hung on to it and now i have a little renewed motivation.
i
vindeta
vindeta
Posted: Tue Jan 19, 2010 11:16 PM
i pretty much have just done a ton of patching and i think im getting close to having the body done, maybe a couple more weeks and it should be good.
i hope so anyway cuz im so tired of welding patches that its ridicules.
i have a bunch of pictures that ill try and post tonight, but right now im going to go out to the garage and do some more welding.
vindeta
vindeta
Posted: Sun Jan 24, 2010 05:03 PM
i got alot farther than i was hoping this week and now i have all the patching done and the heater channel bottoms welded on.
*all these pictures are a couple weeks old ill post recent ones of the finished work in a couple if days*
vindeta
vindeta
Posted: Sun Jan 24, 2010 05:09 PM
i had to cut the sides of the heater channels off cuz they were so rusted
i used vw body metal from the other car (door panels) for most of the patching that i have done.
i bent a 90* into the metal and then welded it onto the heater channel sides.
vindeta
vindeta
Posted: Sun Jan 24, 2010 05:12 PM
i welded it all up and it didnt turn out too bad but its a little rough.
it gets covered with herculiner anyway so it doesnt matter what it looks like.
vindeta
vindeta
Posted: Sun Jan 24, 2010 05:15 PM
this is about what my car looks like right now.
with my fearsome guard dog Laughing
all these pictures were what it looked like as of a week ago.
ill take recent pictures of the completed heater channels and post them.
what do you guys think??
Posted: Sun Jan 24, 2010 05:42 PM
You're doin' good, man! Keep up the momentum!
IMAGE hint- when you copy and past the "img" line of script from photobucket, the image tags that photobucket has attached to it will suffice over here in the thread. It looks like you're adding another set from here- unnecessary. That's why all your pics have visible IMG tags next to them. Smile
Posted: Sun Jan 24, 2010 10:48 PM
I think you have a toe in problem with your car. That will be a little hard on the tires, other than that great progress.
vindeta
vindeta
Posted: Mon Jan 25, 2010 04:56 AM
thanks for the encouragement. im hoping to maybe drive this someday Cool
awesome thanks for the info now i dont have to spend a ton off time copy paste'ing to the "add image" box.
vindeta
vindeta
Posted: Mon Jan 25, 2010 04:58 AM
Laughing Laughing yea my steering box was slipping so i took it out. i have another one from my parts car that i need to put in.
the driver side inner-tube was popped but i think that other than that my tires are strait.
i have non-radial, tubed tires in the front....will that be a bad thing? not having radials? (in the back i do have radials tho)
vindeta
vindeta
Posted: Sun Feb 07, 2010 03:34 AM
finished all the interior wleding and cleaned it up with a wire wheel, belt sander and palm sander.....WAY faster than hand sanding.
5 Admin_AzBaja 8409 Baja Bugs on Wiki need...
1569 mufasavnvmc 1061927 Re: what did you do to...
 Sat May 11, 2019 07:20 PM
285 MusicManiac 256002 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 1257 FREE VW BAJA'S
0 Northmountainauto 2197 Shop Baja
